11-19-2006, 10:08 AM | #1 |
NCStroker
Stance Questions?
im going to be lowering my truck pretty soon. its a long bed and im for somewhat of a rake with the front being a little lower than the rear. my thoughts were to lower it 3 1/2 in front(spindles and 1 inch springs) and 3 inches in the rear with springs. will this put the rear up way to high? should i go a little lower in the back. will also be swapping out the tires for around a 285/65/16 in rear and 265/60/16 in front. thanks for the input.
1971 Chevy C/10-Built 383 Stroker |
11-19-2006, 12:29 PM | #2 |
Chinook Arch
Re: Stance Questions?
Great looking truck!
With the tire sizes you have indicated, the rear tire is nearly 2" taller than the front tire. (I built a quick excel tire calculator, and your fronts are somewhere in the 28.5" tall range, and your rears are in the 30.5" tall range) My truck, with a 3.5" front drop, and a 5" rear drop on 235-60/15 front and 275-60/15 rears, has nearly the same height difference (26.1" front, 28" rear), and the gap from the top of tire to the bottom of fender is pretty even from front to rear. Bottom line is, I think you will have quite a bit of rake with only a 3" drop in the rear. I would suggest either more in the rear, or less in the front, or put air bags in the rear, then you can vary the drop to suit your needs.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus. Elsie's truck 2.5" dual exhaust with Hooker Aero Chambers Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350 ECE drop 3.5/5 |
11-20-2006, 12:09 AM | #3 |
NCStroker
thanks for the ideas...anyone else have anything they have tried?
11-20-2006, 01:17 AM | #4 |
The Hammer Man
You should leave it. Its beautiful just as it is
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
11-20-2006, 03:20 AM | #5 |
it looks just right to me now but to each there own
common sense isn't so common anymore |
11-20-2006, 01:12 PM | #6 | |
Your rake is gonna be pretty steep with the combo you plan on running. C-10s generally came from the factory with 2 inches difference in front and rear height. In effect, your package will have the rear about 2.5 inches higher in the rear. Then add another inch, considering that your rear tire is approx. 2 in taller than the front, making it 3.5 inches rake. Here is a side pic of my truck to show the rake I have. It's lowered 4.5inches in front and 5inches in the rear. The tires are 255/45-20 front and 295/45-20 rear. In effect I have 2 to 2.5 inches rake. Hope this helps. BTW.....my compliment echoes the others when I say your truck is super sweet just the way it is. Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) Last edited by novajess1972; 11-20-2006 at 01:13 PM. |
11-20-2006, 02:52 PM | #7 |
WTB this ad
I just helped member 71see10 drop this one 2.5" front and 5" out back. It still has a rake but it is very mild.
My truck is dropped 3.5" front and 6" rear. Still only a very small amount of rake. I'm guessing you are going to want more than 3" of drop on the tail end of that one. |
