11-19-2006, 07:58 PM | #1 |
hood springs
So I got my new hood springs, and I' ve looked in my shop manual, but I cant find how to replace the spring. Any tips?
11-19-2006, 09:23 PM | #2 |
Re: hood springs
first prop the hood up with a stick or something.. Then you can loosen the front bolt on the hindge and remove the rear bolt and the hinge should move close enough to take the spring off and put one back on.. Mark the location of the hinge first so you can put it back where it was so the hood will stay lined up...
11-19-2006, 09:43 PM | #3 |
Re: hood springs
thanks !!!! I knew some one wolud come thru
11-20-2006, 10:21 AM | #4 | |
Re: hood springs
11-19-2006, 09:44 PM | #5 |
Re: hood springs
The way I installed/removed mine is to use a piece of nylon rope to stretch them. Hook one end and use the rope to pull the other on. Make sure you dont use something that will break. Dont know how much damage it will do, but I dont think it would be pretty.
11-19-2006, 09:46 PM | #6 |
Location: vacaville ca, because it as far from indy as i can be
Re: hood springs
x2
11-19-2006, 09:46 PM | #7 |
Re: hood springs
My assembly manual actually showed a picture/part number for the spring remover. I looked like a hay hook. Basically shaped like a "J" with a handle on the end.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
11-20-2006, 10:14 AM | #8 |
Hollister, CA.
Re: hood springs
AAaaaah, just pry that SOB off with a screwdriver...you'll be fine !!!
JK !!! John Pictures....Slepy...Pictures !!!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
11-20-2006, 11:37 AM | #9 |
Chevy Truck Addict
Re: hood springs
Similar to the rope trick a couple of other guys have posted, wrap a rag or small towal onto the end of the spring and wrap it around your hand. Stand on one end of the hinge and pull.
Using a rag or something soft is a good way to replace the spring as it will not damage any paint or other finish you have on your hinges and springs.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
11-22-2006, 12:36 AM | #10 |
Re: hood springs
rope tricked worked great !!!, The springs came of easy. But..... the new springs didnt go on . I needed some one to " convince" them in to the slot. Oh well there is always tomorow.
11-22-2006, 01:06 AM | #11 |
Re: hood springs
yeah the side that i could use my right hand on went like butter, the one i had to use my left hand was a little harder.
