crank pulley clearance problems
carnk pulley won't go on its hitting the front crossmember bbc using front mounting holes anyone run in to this problem if so whats the fix underdrive pulleys and where can u get some for lwp setup?
Re: crank pulley clearance problems
are the frames different for 67 compared to 68-72 since 67 wasn't avaliable with a big block?
its hitting here
Senior Moment
![]() Join Date: Mar 2002
What mounts do you have? Are they for sure BB? I think SB sets the engine down further. Someone correct me if I'm wrong
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
It may just be the photo but the crossmember looks distorted or bent. It should be flat going across the rails. Those get bent very easily. That would cause the crank pully to hit.
I'm not saying it is bent but the photo makes it look that way.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
The Older Generation
Bob: That crossmember looks that way from that angle. I think his is OK. (I had to go out and check my frame to make sure)... ![]() prostreet1967: I tend to agree with 1970 CST Short Wide, my 454 is about an inch above that x-member at the front of the pulley with '72 BB motor mount towers. LockDoc
#7 | |
Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
I have the same issue on my 67 c10 with bbc swap. Previous owner torched clearance. Looking to replace with stock cross member to improve appearance.
its all about the +6 inches
I've seen a few back yard swps that had that area cut. Never looked into the reason though.
67 frames are a little different than later ones, but I', thinking it was width. a short water pump might help, thats what was stock motor mounts and the stands may be to blame. |
