11-21-2006, 01:31 AM | #1 |
Out of the carpool lane.
Can anyone id this proportioning valve?
This is out of a '67-72' truck, but I don't know what it goes to and whether it would work on my '67. I currently have the prop valve from a '77 down on the crossmember below the radiator and want to move it. Now that I think about it, I might be able to still use it and just use the bracket from this to mount it by the booster. Also, would I be able to media blast this clean again and just blow it out thoroughly before installing? Anyhoo, does anyone know for sure what this is from?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
11-21-2006, 05:26 AM | #2 |
Re: Can anyone id this proportioning valve?
ok. That is a 71-72 disc brake proportiong valve. You could media blast it just be sure to plug all the holes with pipe plugs so no sand gets in there.
11-21-2006, 05:29 AM | #3 |
Here is a pic to help you out.
11-21-2006, 07:53 AM | #4 |
67-72 Addict!
Brad, that looks like the one I cleaned up last night . Mine came off a 71'. I used a wire wheel on a dremel to knock the rust off before painting.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 11-21-2006 at 08:11 AM. |
11-21-2006, 01:10 PM | #5 |
Same as this one I pulled from a 71 C-30. The large port hanging off the bottom/rear is for trailer brake lines. More than likely it's from a 3/4 or 1 ton truck.
