Old 11-26-2006, 12:51 AM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
ViAir wins db drags
Has anyone ever done a comparison of 12v compressors to determine what is the most efficient compressor that is not a contender for the db drags?
My ViAir 400 does a fine job of filling my tanks in a rather short period. I have no complaints about it's efficiency or reliability. I do have a huge complaint about how loud it is. Even though it is mounted at the very back of the truck right behind the rear bumper it is still very load inside the cab.
Does anyone know what 12v compressor is efficient "and" quiet.
BTW-Please don't tell me to run a York....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-26-2006, 01:43 AM   #2
jimmydean
jimmydean's Avatar
Re: ViAir wins db drags
The first thing my wife said when she pulled up and my Thomas was running is "That thing is loud as hell!". I couldn't hear her because that thing is loud as hell
I have a Thomas 377 (plder version before the 337) and it is mounted metal to metal on the frame rail. It takes about 6 minutes to fill my 7 gallon tank. I was just looking at the dual 380 kit for speed.
I think once I mount it on some rubber bushings it will be a little better, but 6 minutes to fill is insane. I'm sure I won't be playing as much as I thought I would with that sort of response time.
jimmydean is offline   Reply With Quote
Old 11-26-2006, 10:38 AM   #3
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I posted some interesting comparisons on Jimmydeans post about his truck between the 450 and the 380 Viairs. The biggest difference between the 2 for me is that the 380 is a true 200psi rated compressor as opposed to the 450 only being rated to 150. Can you run the 450 to 200? Probably so, but for the 380 being only 12 seconds slower from 110 to 145psi and being "rated" to 200 psi, I would choose that. The more psi you can get in your tanks the more play time/reserve time you have.
380C: 12-Volt
• Permanent Magnetic Motor
• Duty Cycle: 100% @ 100 PSI, 55% @ 200 PSI
• Max. Working Pressure: 200 PSI
• Amp Draw: 16 Amps
450C: 12-Volt
• Max. Working Pressure: 150 PSI
• Amp Draw: 19 Amps
450's draw more amps as well, and if you're running 2 of them simultaneously then it can add up. More amps equals more draw on your battery/alt and also equals bigger gauge wire. I chose to run the 380's also because I could run (1) pressure switch/relay for both of them. It simplified my install.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 11-26-2006, 12:47 PM   #4
Grunion
Grunion's Avatar
You guys should try the Air Zenith compressors if you want fast. They're just as loud but way faster.
http://grunionfabrication.com/
Grunion is offline   Reply With Quote
Old 11-26-2006, 03:05 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Grunion View Post
You guys should try the air zienith compressors if you want fast. There just as loud but way faster.
I was going to comment that I heard the AZs were quieter, but I may be misinformed.
What have you got against ED?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-26-2006, 05:21 PM   #6
SCOTI
SCOTI's Avatar
Picture a York wedged between all that cleaned-up & smooth engine compartment....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-28-2006, 12:23 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Yeah, Scoti got it right. Yorks are bad @ss when it comes to moving air, unfortunately they are uglier that a buck tooth hound dog.
My compressor is mounted at the rear of the truck on the last crossmember. It mounted on the rubber feet so it's not resonating through the frame, it's just freakin loud.
Articles-
"Refining Sierra"
Old 11-26-2006, 03:37 PM   #8
Shane
Shane's Avatar
Who's ED?
Shane is offline   Reply With Quote
Old 11-26-2006, 03:51 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Shane View Post
Who's ED?
Engine Driven.
-Chris
Old 11-26-2006, 11:25 PM   #10
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
The AZ's are great but they had lots of probs with the first batch. I would call and make sure they have been fixed. The viar 450 is the loudest mid size compressor I have heard. They are dsependable as hell though and can hit 200 no problem. Thomas' are too slow !
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 11-27-2006, 02:45 PM   #11
Tony@AirRideTech
Junior Member
The biggest noise makers I have heard when mounting compressors is when people take and mount them on or around another loose panel and the sit there and vibrate like crazy. Rubber mount the pumps for sure and make sure that what ever you are mounting them to is solid. If you are mounting on a sheet metal skin be sure to use some dynamatt or some kind of sound deadener ........
Tony@AirRideTech is offline   Reply With Quote
Old 11-28-2006, 01:05 PM   #12
bodydropped
az are goin thru some bad times right now theres a big recall on them but viair has a twin pack out the 380s are dang good but the 480s are loud thou but im goin to run an york i dont care if its ugly or not but nothin that sheet metal cant hide plus i got bolt on brackets for a 350 so im ahead of the game
bodydropped is offline   Reply With Quote
