11-26-2006, 05:51 PM | #1 |
Heater blower problem
My blower in my 68 hasn't been working this winter. So I checked all the fuses which were all good and then replaced them anyway just for the sake of doing so. So I thought, OK it's the blower motor. I bought a new one, installed it, turned on the heater and NOTHING happened. So I now have all new fuses, a new blower motor and no heater. I've checked all the wiring and everything looks to be ok. What am I missing? Thanks in advance. -Moneypit
1968 Chevy C10 1967 Mustang 1976 Honda XL350 2006 Victory Vegas 8-Ball 2012 Ram 1500 4x4 |
11-26-2006, 06:46 PM | #2 |
Re: Heater blower problem
Do you have a ground wire going from the blower to the cab? If no try that first. If that doesnt work then unplug the switch and use a volt metter to see if you got voltage in the plug. If you got voltage then check te switch for continuity. If the switch checks out then it probably is the resistor. To get to it remove the glove box liner and it should be on top. It is held in with 2 screws. Hope this helps.
11-26-2006, 08:17 PM | #3 |
Thanks. I will try that tomorrow. Yes the ground from the blower to the cab is present. Thanks for the info.
