Door sill plates
My after market door sill plates don't fit right. The back is okay, and the screw holes line up. But the front "extension" that curves up comes out over the outside of the door weatherstrip.
Is this just me, or has anyone else had this problem? Do I try to bend it back or should I just cut it off? I tried switching them from one side to the other. No difference. Thanks |
So Many Ideas, So Little Money
I don't know, but if they piss u off enough u could give them to a fellow Iowan
![]() Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
just took mine out Paul, they slide UNDER the weatherstripping.
i just bought some from lmc and they fit ok. but they arent as good as the original ones. just shinier. who'd you buy them from?
FOUNDING MEMBER OF THE DRUM BRAKE CLUB 69 c-10. turquoise. 350 motor with 400 trans. long fleet. headers and dual flowmaster exhaust. K & N air cleaner, aluminum wheels and radials, stereo system and a bed liner. Manual drums and manual steering. Kickin it in Seattle, WA p.s. i love my longbed. must be a phallic thing. |
We stock the G.M. NOS sill plates still in the G.M. packaging if interested, I have not seen the aftermarket sill plates. Are they pretty good quality?
Rest in Peace Ed. Thanks for all the good times. |
Have had several sets of aftermarket sill plates. They work OK but you need to "carefully form" the curved ends to line up with the rubber weatherstripping on both the front and rear. They hold the weatherstripping into the corners so that when your big feet kink into the weatherstripping getting in or out, it stays put. They seem to be generic with regard to left side or right side. I have used some paint to seal the undeside of them so they don't rust as quickly. Currently in use 4 years with no problems. Believe I paid like $25. a pair---came with bowtie, GMC etc. Stainless screws were included.
Thanks guys. Gonna bend one end a bit and hope it doesn't kink. Truck is kinky enough as it is.
chevy2racr - What do you race at Eddyville, and in what class? |
