11-27-2006, 02:19 PM | #1 |
56 chevy project
Well here are a few pics of a little work on the firewall and the new mustang II cross member. I am looking for a turbo 350 so that I can completely mock in the engine and tranny and get the motor mounts welded in.
I hope these pics show up right.
1956 chevy 3100 short bed small window- TCI mustang II with 2" drop spindles, smoothed firewall, CPP brake booster, chevy 10 bolt with disc brakes, c notched. http://67-72chevytrucks.com/vboard/s...d.php?t=217757 |
11-27-2006, 03:49 PM | #2 |
Re: 56 chevy project
Your moving in the right direction nice progress. Great looking job on the firewall and the frontend.
11-27-2006, 04:15 PM | #3 |
The cab is back on to mock up the motor mounts.
11-27-2006, 09:12 PM | #4 |
Looking good! Keep those pictures comimg......did anyone tell you how much we like picturs!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
11-29-2006, 08:44 PM | #5 |
I got the turbo 350 today and thought the installation of the motor and tranny was going to be really simple but it turns out the motor mounts I have are a little too long and they were making the motor sit too high and the trans was not clearing the transmission access panel. So I am having to cut the mounts down a little. Just a little pain in the butt.
Also is anyone else using the tubular a arms from TCI? The grease zerks in the ball joints are screwed into a round piece of metal in the ball joint and when I try to take them out they just spin in place. Does anyone have a secret to screwing them in or out? Do I have to have the full weight of the car on the ball joints to have the piece not spin?
12-05-2006, 02:44 AM | #6 |
Well I mounted the motor and the tranny in. Now it is time to start to save up for the 4 link for the rear.
01-02-2008, 12:39 PM | #7 |
It has been a while. Family and I had to move to Cali and now I am a full time college student so not much time or money to spend on the truck but here are a couple of updates.
01-02-2008, 01:01 PM | #8 |
I tried uploading more images but I believe they are too large. Sorry
01-02-2008, 09:44 PM | #9 |
Here are the other pics that I was trying to upload. Got the C notch done and finished up the fender tips.
01-04-2008, 04:45 PM | #10 |
I am envious in a good way for you. I am working on a 67 waiting my chance to put cab corners on a truck like yours. Please keep showing everyone progress. I have found a few cabs like that in the weeds and am going to get one going again when I can find a warm dry place for it. I will be looking for your progress for more inspiration.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched |
01-04-2008, 07:52 PM | #11 |
Thanks but it is going to be a long process. School and family are priority right now. But after graduation I should have more time.
06-17-2008, 11:25 PM | #12 |
So I bought some bear claw latches this weekend and decided to go for it. Here is the drivers side I am currently working on the passenger side and am documenting it better than the driver side. These close so much better than the original.
06-18-2008, 02:35 PM | #13 |
Looks good so far should have took alittle more time in mocking up the door latches and thought it out alittle better. The rod coming off the inside handle should be lengten and bent slightly and attached with a bolt to the upper latch release on the bear claw, also u need to recess the latch in the door panel instead of bending the latch outer plate and not making it sit flush with the door jam area for a clean looking install. Question what are you going to do about the big gaps on top and bottom of latch and the latch itself is exposed to the inner door panel instead of inside the door itself? Good luck with the progress on your build keep it up. just my opinon
