Frame crossmember rust issues.
As you can see by the pictures my middle crossmember (correct name?) has a few rust issues. What's the best fix for this? Should I start hunting a replacement piece or weld some plates over the holes? yellow arrows are the only rust problems, blue circles are the rivets that hold the piece. thanks...
'69 Step
Re: Frame crossmember rust issues.
I'd start looking in the boneyards..
Drill it out, fabricate a plate to weld over the piece all the way to the edges and then reinstall with grade 8 bolts.
![]() Join Date: Jun 2002
I'd bet that piece could fall out and you'd never know it! I agree, cut out the rust and patch it.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
i would cut the rivets and remove it so you can get to the rust between the layers of metal. (between the frame and crossmember). And then patch and weld. I cut over 50 rivets off my 4x4 frame and replaced them with bolts.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
I think i'll go that route. The piece is secured at the top and bottom so it is still doing its job. The problem with the boneyard is that everything has a bed on it, and i'm not crawling under one for this piece! thanks for the tips, hopefully this is my only structural problem, as you can see I have a bit if surface rust on the frame.
anyone have this part? only found on 4Wd frames I guess...
