11-30-2006, 05:35 PM | #1 |
Tilted (hood tilt build thread)
Well it is not a new idea but I needed a new hinge set up to clear my front tires when the airs out and the frames down. I will be doing a write up for others that want to do this to their truck. I have only the front mocked up right now and I am headed out to built the rear slider latches. This step is one I have not seen any other person complete and post pics of so we will see how it goes. Wish me luck, I want to have it finished up tonight for the mock up stage then I can build the final mounts and give dimentions.
Kevin LFD Inc. |
11-30-2006, 06:13 PM | #2 |
Where's my beer?
Re: Tilted (hood tilt build thread)
Awesome! can't wait for you to do a write up
Paul How do you make the invisible, visible?.........You take it away. |
11-30-2006, 06:21 PM | #3 |
The factory slider/hooks work great Now I just need to pull it all back apart and build the final mounting brackets and clean everything up for viewing
Kevin LFD Inc. |
11-30-2006, 06:25 PM | #4 |
I've been wanting to do the exact same thing! Now I'll know how a "Professional" does it.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
11-30-2006, 06:54 PM | #5 |
Life, Be In It.....
Wow you did all that since I lelt earlier today. Nice
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 11-30-2006 at 06:54 PM. |
11-30-2006, 07:11 PM | #6 |
The LuvShack Garage
So how much is this kit gonna run me?
11-30-2006, 11:01 PM | #7 |
Thanks guys I will be building the finish brackets in the morning and try and have it done before quiting time. It will almost be a full bolt-in kit. It will require Two pieces to be welded to the radiator support and 2-4 nuts to be welded to the front brace of the hood. I will make templete's of all the parts for later use. As of now I do not plan on doing any kind of a kit for sale but I would like to do a write up for the board.
Kevin LFD Inc. |
11-30-2006, 11:05 PM | #8 |
Designated A-hole!
A write up will be well appreciated.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-30-2006, 11:21 PM | #9 |
Do you think any dimensions would have to be changed for a 67/68 front end? Is the front underside of the hood different on the 67/68 hood?
TIA - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
11-30-2006, 11:32 PM | #10 | |
Kevin LFD Inc. |
12-01-2006, 12:21 AM | #11 |
I would love to see / have a copy of your templates for the mounts (front & rear).
This is the mid 80's Buick LeSabre hinge and latch, right? |
12-01-2006, 07:18 AM | #12 |
MY EX DRIVES A BROOM
i gotta get in on this
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
12-01-2006, 09:29 AM | #13 |
Question: are you still going to use the factory truck front latch as well?
12-01-2006, 10:28 AM | #14 | |
Kevin LFD Inc. |
12-01-2006, 11:50 AM | #15 |
Big Block Short Bed Stepside
I got 1 for you Rok how about a complete flip front end like this with out the cut on the the middle of the front rear portion of the fender like the fiberglass kit.
12-01-2006, 12:24 PM | #16 | |
But if you want to do a flip frontend without a fender seam you will need to have your front pivit lower than the rear bottom portion of your fender so when it starts to lift tehfirst action is forward and away from the body and not into it. For this reason it would only work out ok on a 4x4. Here is a quick pic. The pink line shows the pivit point that will pull the fender away from the door as soon as it starts to lift but needs to be low to the ground. The blue color shows how if the pivit is raised up the fender will run right into the door as it lifts. This is why you see fenders cut at an angle and a raised up pivit piont on 2wds. Not to mention your cowl would need to be modified to work as well. Hope this clears things up Kevin LFD Inc. Kevin LFD Inc. Last edited by Rokcrln; 12-01-2006 at 12:25 PM. |
12-01-2006, 01:48 PM | #17 |
Kevin - My BAD. Looking back I can clearly see the 68 GMC hood. I apologize for making you waste your time replying to my stupid posting. If I had opened my eyes in the beginning this would not have been necessary.
Sorry - Bob
12-01-2006, 02:02 PM | #18 |
Kevin, I wanted to cry when I saw that brand new 68 hood cut on the underside.!!!!!! Looks good.
12-01-2006, 03:09 PM | #19 | |
Sorry Bob~ No problem, now people know it may not work on a 69-72 as it is curently built! All's good Kevin LFD Inc. |
12-04-2006, 01:10 AM | #20 |
have you gotten everything all buttoned up yet? Sounds like it's going pretty smooth!
12-04-2006, 03:41 AM | #21 |
THE VILLIAGE IDIOT
i like it..great idea..cant wiat to see the write up..but how do you open it..but dont wory abotu an answer i know you will show it later on..great work by the way..
billy
honestly honey,,i have no idea how that truck got here. |
12-04-2006, 08:40 AM | #22 |
http://67-72chevytrucks.com/vboard/s...d.php?t=218253
Here it is, I posted it in the blazer forum since it is a bit slower I had time to get it all on here before people started responding. As far as opening you just use your stock latch Kevin LFD Inc. |
12-05-2006, 10:48 AM | #23 |
Rok why do you feel that a complete flip frt would be harder to work on. I want to do this as it would alllow easy accese to the motor if done properly like an 18 wheeler. I would be will to work some thing out with you if you would be intrested.
12-05-2006, 04:27 PM | #24 | |
Fabricate till you "puke"
http://community.webshots.com/user/hotrodhorn L BTW....damn nice work on that hood!
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
