11-30-2006, 11:03 PM | #1 |
73-87 3" djm lower control arms?
i was just wondering if anyone has has heard, or has had any experience with djm 3" lower control arms? i know it will give you less ground clearance, but what would be any more drawbacks? also how do you think this would work with their 3" spindles.
11-30-2006, 11:28 PM | #2 |
It'd be alot cooler if you did
Re: 73-87 3" djm lower control arms?
it won't work with 3" spindles at all, the wheels will rub on the control arms. Just use a spring in combination with a 3" spindle. The poly bushings that come in the control arms also squeek like hell if you dont grease the crap out of them.
11-30-2006, 11:58 PM | #3 |
Even if you grease the crap out of them!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
12-01-2006, 10:57 AM | #4 |
the truck is bagged and im running 22" wheels, would that work?
12-01-2006, 04:27 PM | #5 |
I think it would work the 22s should give you the clearance and with teh large wheel the ground clearance of the lowered pocket shouldent give you a problem butt i have never seen it so i guess you will be the one who has to try it and tell us how it worked out
http://www.cardomain.com/ride/2461088 |
