12-03-2006, 12:50 PM | #1 |
Mad Scientist
How to lower?
My swb 79 has the T400 and two drive shafts with a carrier bearing in the middle. Any lower really throws the alighnment off. Is replacing the shafts with a single my only choice?
Everythang relates to Beer! 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
12-03-2006, 01:13 PM | #2 |
Re: How to lower?
hey i posted the exact same thing several months back,and i think everybody thought i was crazy,i had several post saying they never heard of a two piece in a short bed,truth is 67-72 it was pretty common. i don't know why they did it,i heard because the rear doesn't line up left to right with tranny very well,2 piece drivelines are common on a lot of lowrider sites even being favored and produced new aftermarket over 1 piece they take away vibration.what i ended up doing was taking it in and having a couple inches taken out of the carrier bearing housing bracket that leveled it out.they wanted about 300 for a new one piece.or you could try junkyard.for 1 piece.people will say shims ,but if your angle was like mine shims aren't near enough.i just had back surgery and can't get under there anyway to take a pic or i'd post one of how it turned out.
12-03-2006, 02:02 PM | #3 |
Mad Scientist
Re: How to lower?
Thanks. I hear the same when I mention carrier bearing. This is my third SWB with one. Seems the T400 is also involved somehow
12-04-2006, 02:12 PM | #4 |
Re: How to lower?
you may be on to something with that turbo 400 explanation.the other 79 i knew of had a 400 also.that carrier bearing bracket is the cheapest easiest way to straighten out the angles,no bad vibes.by the way my nephew's playing minor leauge pro basketball down there in arkansas for the rimrockers.
12-04-2006, 05:07 PM | #5 |
Re: How to lower?
No to muddy the water but the 86 SWB and the 87 SWB I recently junked both have (had) a TH400 with a one piece drive shaft.
12-04-2006, 05:30 PM | #6 |
Re: How to lower?
yeah...i don't know what determined the way they decided at the factory 1 piece sure outnumber 2's but there must of been some explanation,be kinda cool if somebody that actually worked at gm could give a concrete explanation.
12-05-2006, 02:03 AM | #7 |
Re: How to lower?
I have a 73 SWB with the two-piece driveshaft also. Was going to post that "why" question tonight but a quick search turned up this thread - perfect!
And the rubbery donut thing that seems to hold them up has a LOT of play between it and the metal piece securing it to the frame. Wondered if a single driveshaft might be better and then got to wondering why they had the two pieces in the first place. It's a factory 454 truck but how do I tell if 350 or 400 trans? G.
73 Shortbed 454 Last edited by Gandalf; 12-05-2006 at 02:03 AM. |
12-05-2006, 08:52 AM | #8 |
7000 #'s of american IRON
Re: How to lower?
350= texas pan 400 = mostly square (or not texas pan, either way)
12-05-2006, 09:29 AM | #9 |
Mad Scientist
Re: How to lower?
350 pan is square with a rear corner cut off. 400 has two "rounded out" corners on one side. A 400 also has an electrical kickdown instead of a 350 type cable coming from the pass. side front of trans by bell housing.
Everythang relates to Beer! 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger Last edited by hiway; 12-05-2006 at 09:29 AM. |
12-05-2006, 01:57 PM | #10 |
Re: How to lower?
the 2 piece drive shaft was/is better for towing/hauling. a lot of late model trucks still have the 2 piece driveshaft
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
12-05-2006, 03:07 PM | #11 |
Mad Scientist
Re: How to lower?
I would understand the reason....in a long wheelbase model.
