Old 12-04-2006, 07:30 PM   #1
ScottH
ScottH's Avatar
Will a Blazer gas tank work in a SWB truck?
Anyone know if I can use a 31 gallon blazer gas tank in a swb k10 I'll be picking up soon?
Any info is appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 12-04-2006, 07:35 PM   #2
84 400
Sb 400 club
84 400's Avatar
Re: Will a Blazer gas tank work in a SWB truck?
with mods yes! will it bolt in the stock saddle bag location no
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-04-2006, 08:15 PM   #3
bigblock73
yeller
bigblock73's Avatar
Yup, Chris did it...
http://www.captkaoscustoms.com/blazertank.html
bigblock73 is offline   Reply With Quote
Old 12-04-2006, 08:54 PM   #4
ScottH
ScottH's Avatar
Thanks guys. Is there anything that would basically bolt in to increase the capacity? Original optional larger tank, or other years that would work?
Old 12-05-2006, 12:20 AM   #5
84 400
Sb 400 club
84 400's Avatar
do you have twin 16 gallons or a single 16? you can put in twin 20 or a 20 gallon but i tried it on my old truck and never got the filler plugg figured out but i never really tried eather.
1985 C10 LWB Sold
Old 12-05-2006, 10:36 AM   #6
ScottH
ScottH's Avatar
Just a single tank which is why I was looking into something larger.
Old 12-05-2006, 12:28 PM   #7
Slonaker
Insert Witty Text Here
Slonaker's Avatar
You could install another saddle tank on the other side. It was a common factory option. They are filled separately, and controlled by a switch on the dash. It also switches between the sending units of the two tanks so you can check both with one fuel gauge.
The only problem is that trucks with two tanks have fillers on both sides of the bed. If your truck came with a single filler, you would need to switch beds to one from a dula tank pickup, or modify your existing bed.
The issue with the Blazer tank, I believe, is related to the filler as well. You would need to fabricate something to allow you to fill it with gas.
My dad's old truck that we had in the 70s just had a fabricated steel tank bolted into the front of the bed, kind of like the toolboxes you see now. It was plumbed in with a tee and a manual valve that was mounted through the floor between the seat and the door. It wasn't pretty, but it allowed the truck to carry a huge amount of fuel.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 12-05-2006, 03:08 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Filler for the Blazer tank can be addressed simply by routing it up to the bed floor if you were so inclined..
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-05-2006, 03:31 PM   #9
Slonaker
Slonaker's Avatar
The downside is you can't fill the bed with stuff and then fill the tank. I guess that might not be an issue is he has another tank to work with...
Slonaker
Stock '01 Silverado
