Old 12-04-2006, 10:55 PM   #1
my67C10
my67C10's Avatar
removing the bedsides HELP!
well i got all the bolts out on the driver side and there are two welds that I ground down flush to the other sheet metal ( i dont want to grind into other sheet metal). My question is how do i get the rest of the welds off? I was able to use a air powered jack hammer (hand held, very small) to brake the welds on the horizontal one but i cant get the vertical one to brake. HELP!!!
my67C10 is offline   Reply With Quote
Old 12-04-2006, 11:13 PM   #2
ks147j111928
ASE Certified Spoon Operator
ks147j111928's Avatar
Re: removing the bedsides HELP!
Last month I disassembled a longbed and I ran into something like this. Depending on what you want to save, try a cutting wheel if you have the room. Are you talking about the rear stake pockets? You should be able to get away with a little chopping, maybe with a cold chisel and BFH. I ended up prying the stake from the floor with a big prybar, not my first choice but it was getting late.
My six is bigger than your eight
67 K20 292 +.060" SM465 NP203 3.73s
86 4Runner, the daily on 31s
85 4Runner, the wheeler on 38s
92 x-cab truggy project for 2017... tons and 42s and V8 power
ks147j111928 is offline   Reply With Quote
Old 12-04-2006, 11:14 PM   #3
krue
Designated A-hole!
krue's Avatar
Are they spot welds? You may need a spot weld cutter. I assume your working on a fleetside, 'cuz there's only one weld per side on a stepside.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-04-2006, 11:49 PM   #4
Primered_69
Primered_69's Avatar
Cut off wheel for the weld. Angle it to get in there real good.
However, Make sure that you did not miss some bolts though. There are two hidden within the rear most bed "crossmember" (for lack of a better word) Standing from the back if you put your hand within the crossmemebr (bed support?) there are two more bolts. At first I did not notice them so just make sure you got them.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 12-05-2006, 03:34 PM   #5
my67C10
my67C10's Avatar
i seen thoes two you are talking about and ive yet to get them all the way off(they are going to snap before they thread off and i dont need stitches)
the welds are about two inches long so im going to have to use a cut off wheel. Thanks for all your help!
HAHA chingadera!! LOL (sorry)
Old 12-07-2006, 07:13 PM   #6
my67C10
my67C10's Avatar
AHAAAH!!! i got the driver side bedside off today! i used a 1/8" drill bit and drilled holes with about 1/16" between holes and used a numatic chisle. now I need to find out where the spot welds are at so i can seperate the inner and outer finders from eachother so i can start taking the dends out.
