Old 12-07-2006, 02:25 AM   #1
Broken_down?
Piston types. Dumb queston but i'm, askin anyway
been looking recently for a complete engine rebuild for our 350. I understand everything in the kit except it ask what type of piston style. It lists: Flat, Dome, Dish. Which of the 3 is best and why for a stock build.
thanks
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 12-07-2006, 02:32 AM   #2
turbochevy
Re: Piston types. Dumb queston but i'm, askin anyway
just depends on what you are looking for.....
what are your plans for the truck?
1970 Chevy C 10 SWB
turbochevy is offline   Reply With Quote
Old 12-07-2006, 02:54 AM   #3
Broken_down?
My plan is to restore her back to complete factory. Everything!
If I get my way and find 327 somewhere then I will drop that back in and restore it back to factory. As it sits the truck is a 68 with a 71 350. I so want to get rid of this 350 and put a 327 back in. But no one around here sells the 327...
Old 12-07-2006, 06:15 AM   #4
Billla
Billla's Avatar
There's not one that's "best" - they're means to get different CR, with dished pistons giving the lowest CR and domed the highest. If you check the kit listing, it will give the CR with each set - probably based on a 64cc chamber.
Billla is offline   Reply With Quote
Old 12-07-2006, 11:50 AM   #5
Myself
At 76cc or 64cc chamber volume, either way, the flat-tops will be a good choice for stock to mild performance builds. Won't cause any detonation problems.
Myself is offline   Reply With Quote
Old 12-07-2006, 12:17 PM   #6
Robznob11
Robznob11's Avatar
yes go with the flat tops, most all sbc heads have small chambers 64-76 some after market heads are even 54cc so with that in mind unless you want to run race gas domes are out of the question not to mention you have clearance issues, no then with the dish you will give up an optimun compression ratio and you motor will not likley exceed 260 hp. flat tops are the best choice becuase you can get about 9-10 to 1 comp ratio witch will work well with all mild tricks you want to add later like cams etc. they also work best if you want to bump them with a small bit of n2o. there are 2 different types of flat tops some with 2 valve reliefe and some with 4 i like the 2 so that you dont give up that extra crunch. also with the flat tops you can fool around with head gaskets to alter your comp ratio and go from mild to wild but thats all the secreats im gonna tell you so good luck...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 12-07-2006, 05:50 PM   #7
Billla
Billla's Avatar
Gaskets vary a bit around .040...you're not going to go from "mild to wild" with that
Old 12-07-2006, 06:48 PM   #8
crazy longhorn
Fabricate till you "puke"
Im not here to talk too much about compression, but more about Quench. No IMO , a 327 or 350 should be set up with a 2 valve releief flattop to keep the compression up on a good street motor.....but... You also want the comp ratio to reflect proper Quench (piston to head clearance), & that should be in the .040-.045 range, with a .035 minimum for steel rods running under 6500 rpms. the tighter you can cut that quench, the more compression you can run without detonating that pig! Also, the more timing you can run without detonation.....ei , a 10 to 1 mill(with proper quench) will run better, with less detonation,& more timing than a 9.5 to 1 mill that has too much quench distance! That is why gasket thickness should not set the comp ratio Now you can "fudge" on the comp ratio, by running a hotter cam,(static comp ratio vs dynamic comp ratio) or aluminum heads.....they loose a lot of heat, & will allow higher ratios(lots of debate there, but generally 10.5 to 11 to1 on alum heads works). best of luck..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-07-2006, 12:18 PM   #9
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Broken Down,
I've rebuilt a 327 (still on the engine stand), for my C-10, using forged flattops and a mild RV cam (268). With what I've chosen I think I can get away with regular gas; just barely. The large journal 327 cores are still out there but, being a 2 year only, they are scarce. Plus there are a bazillion Corvette owners looking for the same block. Good luck! ET
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 12-07-2006, 10:00 PM   #10
BCOWANWHEELS
Aa 1971 350 Is A Excellent Engine. The Best Yr Of The 350,s Is 1970 & 1971. Most Likely You Got A Set Of 461 Heads, Steel Crank, Hi Nickel & Tin Block. If It Was Mine It Would Take 1000.00 To Buy It As A Rebuildable Core. You Know There 300 Hp Stock Right ? Just Build It Back Completely Stock Except Install Hard Valve Sets On The Exhaust Ports Of The Heads.
Bob
BCOWANWHEELS is offline   Reply With Quote
