12-08-2006, 04:22 PM | #1 |
Welding Patch Panels
I Know When You Weld In Patch Panels That You Spot Weld It Slowly And Work You Way Around. I Am Just Doing A Small Piece On The Front Side Area Of The Cab.(behind The Back Of The Fender) I Cut A Piece Of Metal And Spot Welded It, But When I Ground It Down You Could See Some Really Small Holes Or Kinda Like A Small Crack Where The Patch Is. I Know The Crack Is Not Normal, But Should You Be Able To Make It Look Just Like One Piece Of Metal Or Should You Use Like A Sealer Or Filler To Make It Solid?
12-08-2006, 06:19 PM | #2 |
Re: Welding Patch Panels
I would recomend doing some more welding and grinding to clean it up. I am assuming that you didn't get good enough penetration to fill the gap. The small holes were caused by the flux splaterring or just missed a little bit.
1946 Chevy ton truck 1972 Chev C30 1975 Scottsdale C10 |
12-08-2006, 09:58 PM | #3 |
Post some pics......
