12-09-2006, 07:34 PM | #1 |
wnc tvman
Uh-o Leaking Freeze Plug
O well she's frozen. I hope it's just the freeze plug. Famous last words "It's not going to be that cold". My Mom always said a hard head has to feel.
Oz WNC 67 Short Fleet 350 4speed 70 Short Fleet 327 4speed |
12-09-2006, 07:58 PM | #2 |
RIP Mr Ron
Re: Uh-o Leaking Freeze Plug
Well all you can do now is check out the leak and hope it is a freeze plug. If you can borrow a coolant system pressure tester you can find the leak without running the engine.
Ron (Mr Round Tuit) Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
12-10-2006, 12:53 AM | #3 |
so is there an easy way to replace a freeze plug without pulling the engine? mine is definitely the source of my constant water leak.
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
12-10-2006, 03:30 AM | #4 |
RIP Mr Ron
If you can get the leaky one out yes. Go to most any parts store and ask for a rubber freeze plug. It is a piece of rubber sandwiched between two washers with a bolt running through it. Take the old one out and install the new one. Tighten the bolt and it swells the rubber piece to hold it in place. Just make it snug don't over tighten it. It will do the job.
