What's wrong with this picture?
Is this choke hooked up correctly?
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
Re: What's wrong with this picture?
take a bigger picture so i can see the choke plate
looks like you got the incorrect choke spring if thats where it sits cold, the loop that holds the rod should be closer to the manifold.. right now it would be in the center of travel |
heres a picture..
i will go take a picture of the correct coil cold this coil is at 65 degrees in the garage Last edited by rage'nrat638; 07-12-2007 at 07:00 AM. |
i know this is a little late but this is my new carb to get rid of the old coil type choke
this is a hot tube choke carb converted with a edelbrock electric choke conversion kit Last edited by rage'nrat638; 07-12-2007 at 07:00 AM. |
i found it....i got a box of carb parts.. more than likely have the correct spring.
i will go look... |
heres the correct brand new choke spring..brand new..
it's called a devorced choke spring Last edited by rage'nrat638; 07-12-2007 at 07:00 AM. |
member #16
![]() Join Date: Dec 1999
I think you have the wrong thermostatic spring. Mine is wound the opposite way with the rod to the front side. They make different types of springs.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
