Old 12-13-2006, 01:16 PM   #1
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Need some Info!
Does anyone Know if you can inter change the axels on the 69-72 trucks? Meaning I have a 5 and also a 6 lug can these axels be interchanged?
Angelse68cal is offline   Reply With Quote
Old 12-13-2006, 01:25 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: Need some Info!
The axle lengths are different on some. I believe the mid 69 to 72 are the same, and the 67-mid 69 are the same . I could be wrong, i'm sure someone else will chime in to correct me....
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 12-13-2006, 01:32 PM   #3
69rut
Re: Need some Info!
I think centless has it right. The axle shafts are different lenghts. You can exchange the whole assembly. Remember that some axles are coil spring and others are leaf. This would be a different kettle of fish.
trailers are for boats
69rut is offline   Reply With Quote
Old 12-13-2006, 01:40 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
Re: Need some Info!
Axle lengths changed during the '70 model year to the longer ones.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 12-13-2006, 01:47 PM   #5
HuggerCST
HuggerCST's Avatar
Re: Need some Info!
I agree. ^ About 3/4 of an inch longer per side.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 12-13-2006, 04:16 PM   #6
Aarons72s
Re: Need some Info!
You can use the 5 lug axles as they say in the older 67-69 axle housing and go get drums for a 74-87 chevy truck with 11-5/32 brakes. The drum is 3/4" wider than stock and will work fine with the existing brakes,ie 2" brakes. I will go get a link for a thread on this modification.
Here is the linky: http://67-72chevytrucks.com/vboard/s...d.php?t=215095
Aarons72s is offline   Reply With Quote
