Old 12-13-2006, 08:45 PM   #1
chevyboy55
chevyboy55's Avatar
Gas gauge help
I'm sure this has been posted a gazillion times BUT, I got way too many returns when I searched gas gauge,So lets go for a gazillion & one. The gas gauge reads 3/4 full when it's full(better that way than the other way)How can I fix it? It's an aftermarket blazer tank.
chevyboy55 is offline   Reply With Quote
Old 12-13-2006, 09:23 PM   #2
byrd
Union Electrician
byrd's Avatar
Re: Gas gauge help
easiest and cheapest thing to do would be to replace the resistor on the back of the fuel gauge.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-14-2006, 12:53 AM   #3
manimal
manimal's Avatar
Re: Gas gauge help
If the resistor doesnt do it then take the sending unit out and clean the contacts on the reostat.You can use a FINE fingernail file to clean off the gunk that may have formed,then reassemble and try it out.Make sure that you spray off the contacts with carb cleaner or better yet use electrical contact cleaner.If thats not it then it could be that the arm that holds the float is bent.
manimal is offline   Reply With Quote
Old 12-14-2006, 01:19 AM   #4
72armyswbtruck
72armyswbtruck's Avatar
Re: Gas gauge help
Float Arm is the culpret!!!!!!
Without breaking it, try and bend it until you get the correct reading
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-14-2006, 01:44 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Gas gauge help
This should read Float Arm MIGHT BE the culpret!!!!!!
Old 12-14-2006, 05:02 AM   #6
chevyboy55
chevyboy55's Avatar
Re: Gas gauge help
I thought I read something about ohms & what they should be or something like that.As far as gunk that's not it it's a brand new tank & float.Kinda hate to just start bending the arm & that not be it.
Old 12-14-2006, 08:48 AM   #7
byrd
Union Electrician
byrd's Avatar
Re: Gas gauge help
That is why I said to change the resistor on the gauge itself. I onl know of two sending units for the repop blazer tanks and they are rated at 30 ohm 63-66 and 90 ohm 67-72. You can use an ohmeter at the tank and try to see what the sending unit is putting out, but if it were mine I would try the resistor. I have a bunch of them here if you want a known good one for $8 shipped I would be more than happy to help you out on this. I would need a couple of dasy to get one tested and verified as I have been very ill this week.LMK...Randy
Zip:40272
Old 12-14-2006, 02:30 PM   #8
crm318
Alright Alright Alright
crm318's Avatar
Re: Gas gauge help
i had the same thing happen. it turned out to be the resistor. i went to fix-a-guage.com and i bought one of their resistors and installed real easy. it was only like 17 dollars with shipping.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 12-14-2006, 03:06 PM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Gas gauge help
I have the exact same problem (I JUST figured this out yesterday, it's the first time I've put a full tank in the truck) It went just a hair past 3/4 full, exactly as you stated your's does. I have an aftermarket blazer tank in a C-10. Without dropping the tank or removing the bed, I can not get to the sending unit, what does the resistor on the back of the gage look like? I might have to take mine apart this weekend!
When the gage is on E, the tank is empty! So that part is working correctly as I have run out of gas a couple times running the truck around the yard before it was completed. That leads me to believe this resistor is the culprit.
SO byrd, which resistor SHOULD go with a blazer tank? When I take mine apart, if it's different, I can assume that's what is wrong? I'm sure my tank is a 69-72 blazer.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-14-2006, 07:02 PM   #10
crm318
crm318's Avatar
Re: Gas gauge help
the resistor looks like a little white rectangular piece. the fix-a-gauge piece is universal and works on all applications. i would look into that before you get into the tank.
1972 Cheyenne
Old 12-14-2006, 07:15 PM   #11
cdowns
cdowns's Avatar
Re: Gas gauge help
the first place to check is the range of motion of the float arm if it doesn't move thru the whole range of motion it's saupposed to a resistor will do you no good except giving you a false reading
Old 12-14-2006, 09:12 PM   #12
bad72c10
bad72c10's Avatar
Re: Gas gauge help
Do you have enough to send one my way? If it's only $8 It's worth a shot on my '72, it's a stock tank, but won't give me a good reading. If you do, I'll probably send you a PM with my address and get yours to send you a check. Thanks, Justin
bad72c10 is offline   Reply With Quote
Old 12-15-2006, 12:42 AM   #13
byrd
Union Electrician
byrd's Avatar
Re: Gas gauge help
Sure just send me a PM to remind me
Zip:40272
Old 12-15-2006, 01:00 AM   #14
byrd
Union Electrician
byrd's Avatar
Re: Gas gauge help
The resistor is the same for the 67-72 truck fuel gauges. The only difference is the repop blazer tank has two optional sending units (that I know of maybe more??)30 ohm and 90 ohm. Now I am positive that you have the right sending unit as you would not get past 1/3 tank or so if you had the wrong sending unit.You could have a dirty/bad connection across the resistor, you can easily just visually check that. If you have an ohmmeter here is a way to check the gauge and resistor using this guide I have posted and that should tell you where you should look. This should done with the ignition off to protect your meter,you do not want to apply power to your meter when it is in the ohms function as you run the risk of damaging it or blowing a fuse in the meter.
Zip:40272
Old 12-15-2006, 10:54 AM   #15
67ChevyRedneck
Re: Gas gauge help
Shoot, so it's probably not the resistor then? At least it's not the wrong one...
Now that I think about it, I remember testing the float on the blazer tank and I could have sworn that it went to E and F when hooked to the gage.... so what the crap is going on?
Jesse James
Project "On a Dime"
Old 12-15-2006, 12:20 PM   #16
byrd
Union Electrician
byrd's Avatar
Re: Gas gauge help
There is no difference in the resistors, just the sending units.
I would really lean more on it being the resistor as you have stated you tried out the sending unit and it worked fine then. I was just trying to suggest the easiest thing to trouble shoot first, as dropping the tank is quite a bit of work and guess I'm a little lazy. I would make sure it is electrically sound before moving onto the mechanical aspect of it. Just my .02.
Randy
Zip:40272
Old 12-15-2006, 06:43 PM   #17
72GMCburban
72GMCburban's Avatar
Re: Gas gauge help
The truckandcarshop.com has the resistor new for $10, but u have to pay shipping. Take your multitester to the gas station and plug it into the brown wire and start filling up. If the sending unit is working then you should read 90 ohms full.
My question is what do u do when the unit is sending the right ohms and you have replaced the resistor and it still doesn't work? That is where I am now!
---Mike
72GMCburban is offline   Reply With Quote
Old 12-15-2006, 08:17 PM   #18
chevyboy55
chevyboy55's Avatar
Re: Gas gauge help
---Mike
So let me make sure I understand this correctly.It will read 90 ohms when full.Will it have a different ohm reading if it's not full?The bed is off right now & I want to rule out a sending unit while it's still off.
Old 12-15-2006, 08:23 PM   #19
72GMCburban
Re: Gas gauge help
Yeah, it should be lower, plug in the red to the brown wire and the black to a good ground and you can watch it fill up by the ohms. I shouted"cool, i don't need to drop my tank" as strangers looked at me strangley.
This is unbelievable!! I just found info posted here in 2003. All these guys were having trouble with their guage pegged f or empty...the fix? It was the fuse! purple band was blocking the break. Unreal, it fixed mine!
---Mike
