12-15-2006, 06:40 PM | #1 |
sbc / bbc valve train adjustment
The adjustment is 1/2 turn down from zero lash. (GM MANUAL SAY'S 1 TURN)
In order for the hydraulic lifter to work correctly, it must be centered. If your valves have come out of adjustment after several thousand miles of operation, suspect your rocker arm nuts, and replace them. They do wear out after constant adjustments. When adjusting your valves, tighten all adjusting nuts until all lash is removed by feeling the rotation and up and down movement of the pushrod. Next, set your engine on TDC #1, pointer at "0". You can now adjust the following valves: INTAKE on cylinders 1,2,5,7 EXHAUST on cylinders 1,3,4,8 Loosen the adjusting nut until lash is felt by rotating the pushrod. Then tighten the adjusting nut while rotating the pushrod until all lash is removed. Now tighten the adjusting nut 1/2 full turn. This "centers" your lifter. After you have adjusted the above valves, rotate you engine 360 degrees bringing the pointer around to the 0 TDC mark. This is TDC #6. Adjust the following valves in the same manner: INTAKE on cylinders 3,4,6,8 EXHAUST on cylinders 2,5,6,7 Your valves are now adjusted properly. good luck and may the force be with you as per the g.m manual.. Last edited by rage'nrat638; 07-12-2007 at 07:00 AM. |
12-18-2006, 10:58 AM | #2 |
Re: sbc / bbc valve train adjustment
I have used this for years and is the best way. Thanks for posting this, I always have to go to the book.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
12-18-2006, 11:24 AM | #3 |
12-27-2006, 04:12 PM | #4 |
01-03-2007, 05:49 PM | #5 |
WHen you say zero lash which is the same as remove all lash. THat is when you can feel the push rod rotate underneath the rocker and tighten the nut until the push rod just stops the rotation correct?
01-03-2007, 06:11 PM | #6 |
Zero lash is when there is no vertical movement of the pushrod, typically when you just start to feel drag when rotating the pushrod. Tightening until you can't turn the pushrod is far too tight!
01-28-2007, 09:38 PM | #7 |
Ok assuming I have the right TDC on the compression stroke. I tightend each rocker nut until I felt drag on the pushrod then tightend another half a turn. I am thinking this is what mark is talking about. However Billa once I tightend the extra half turn I could not turn the pushrod anymore. Should I loosen it up again so the pushrod turns? Then when I rotated the engine 360 to finish the rest of the valves the pushrods on #1 cylinder can turn again. Now I am confused?
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
01-28-2007, 09:49 PM | #8 | |
What you're doing here is pushing against the spring inside the hydraulic lifter. |
01-28-2007, 10:23 PM | #9 |
Thanks that cleared up the confusion. Now I have to make sure I had the right TDC. I think I did because both the intake and exhaust valves were closed. If I had been 180 out the exhaust would have been open correct? and should I go past 1/2 turn to 1 full turn?
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer Last edited by 65-72 chevytoys; 01-28-2007 at 10:25 PM. |
01-28-2007, 10:37 PM | #10 | |
01-28-2007, 11:15 PM | #11 |
Thanks Billa you have been a big help. I have the valves adjusted and right. Now all I need to do is start the engine and see if that fixed my lifter noise.
01-28-2007, 11:19 PM | #12 |
01-30-2007, 11:31 AM | #13 |
im guessing since the firing order is the same for a small block and big block u adjust the same valves on number 1 and 6
