Old 12-16-2006, 02:48 AM   #1
13lazer
13lazers' blazers
13lazer's Avatar
electric fans
i just wanted to express how much i like the set of fans my buddy pulled from a crusher prototype bmw. i used the wiring circuit that vtblazer described a while back with a ballast resistor from an old points ign for the low speed setting and 2 relays. i sat in beverly hills traffic this last summer for a month or so at a crawl (25 miles in 90 minutes) approx. on some very hot days and it never moved from the thermostat regulated position unless i forgot to turn it on. as soon as i hit the toggle with the engine almost boiling over the needle drops immediately. if you have the chance i recommend a good set of electric fans. they save a lot of gas and my blazer is snappy. i have embarrassed many of the guys that prefer paying finance charges as opposed to building thier own toys. that truck surprises me most of the time
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 12-16-2006, 08:22 AM   #2
vtblazer
vtblazer's Avatar
Re: electric fans
glad it's working well for you, mine works equally as well when wheeling at slow speeds on hot days.
vtblazer is offline   Reply With Quote
Old 12-16-2006, 08:30 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: electric fans
Ok, I missed out apparently Pic's would be nice, and any other info also
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 12-16-2006, 08:44 AM   #4
vtblazer
vtblazer's Avatar
Re: electric fans
He's telling ya electric fans are the way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=209633
Lots of different ways to do it but it's definitely a good mod, IMO.
Old 12-18-2006, 08:01 PM   #5
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Re: electric fans
I am having a problem why do my fans turn on when I turn on the key?
Angelse68cal is offline   Reply With Quote
Old 12-18-2006, 09:59 PM   #6
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: electric fans
because you hooked them into a ign hot wire
trkklr77 is offline   Reply With Quote
Old 12-19-2006, 12:23 PM   #7
Angelse68cal
Cochino_Racing_909
Re: electric fans
Ok so what do I have to do to COrrect the problem because i have a local guy telling me that is the way i should do it But I want the temperature switch to turn it on and off.
Old 12-19-2006, 12:52 PM   #8
Angelse68cal
Cochino_Racing_909
Re: electric fans
Ok so what do I have to do to COrrect the problem because i have a local guy telling me that is the way i should do it But I want the temperature switch to turn it on and off. Where is a switched 12v source in the 67 -72 trucks?
Old 12-19-2006, 01:15 PM   #9
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: electric fans
Have done this mod to all of my classics and will continue to do this mod!
AesC10s is offline   Reply With Quote
Old 12-19-2006, 01:29 PM   #10
Angelse68cal
Cochino_Racing_909
Re: electric fans
I dont want my fans to run all the time only when it gets to a certain temp and the thermo switch turns them on.
Old 12-22-2006, 06:24 PM   #11
jkade
jkade's Avatar
Re: electric fans
For anyone that does not know the dual fan setup from ls1 model camaro or firechicken fits our radiators nearly perfect and they are cheap when buying used.
jkade is offline   Reply With Quote
