12-20-2006, 08:24 PM | #1 |
turbo enthusiast
coil spring question
would front coil springs for a 2wd 1 ton truck fit in the front of a 2wd 3/4 ton truck? They look like they will fit, so I'm guessing the ride will be a just a little stiffer.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting " |
12-20-2006, 09:06 PM | #2 |
its all about the +6 inches
Re: coil spring question
yep, they'll swap fine
12-20-2006, 09:06 PM | #3 |
Living In The Past
yep , they'll fit. I have done it. I have some brand new 1 ton springs if your looking for some.
12-20-2006, 11:57 PM | #4 |
turbo enthusiast
I have some new ones also, but does the 1 ton springs lift the front end up higher than stock? Does anyone make 1 ton rear coil springs for these trucks?
12-13-2010, 11:00 PM | #5 |
But Found Her 25yrs Later!
I was wondering the same thing.
12-21-2006, 12:35 AM | #6 |
Living In The Past
I dont know about the back springs but on the front you need to cross reference the part numbers with 3/4 ton springs where your buying them from. When I was looking for one ton springs I found that a lot of places had the same part # for both 3/4 and 1 ton. If you find the true one tons yes it will sit higher because they wont compress as much with the weight on them.
12-21-2006, 01:03 AM | #7 |
turbo enthusiast
thanx Olden Days
12-14-2010, 01:00 PM | #8 |
I have one ton springs in the front of my 1/2 ton with 3 inch drop springs in the rear. My pic is what you will get.
Fuzzy |
12-14-2010, 02:12 PM | #9 |
wow... 4 year old thread... almost to the day!
There is no such thing as one ton coils. All C/30 trucks had leafs in the back |
12-14-2010, 06:38 PM | #10 |
Do you think there will be such a thing as a rear 1-ton coil in four years from now?
12-14-2010, 07:07 PM | #11 |
Lmao!
