Old 12-21-2006, 02:25 AM   #1
70-c10LWB
pic or info request
I just finished my step notch in the rear and am wondering how low my front will be with suicide doors front brackets and cups cut to 1" with slam re7 bags and 2.5" drop spindles. im trying to decide to Z or not before i start reassembling the front to much. thanks so much
70-c10LWB is offline   Reply With Quote
Old 12-21-2006, 04:16 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: pic or info request
I am in the process of doing exactly as you describe. You should lay the control arms on the ground depending on tire height.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-21-2006, 04:40 PM   #3
pharcyde05
pharcyde05's Avatar
with that set up you should lay a arms that is going to be the lowest part of the truck you wont lay out on frame cause front cross memeber will hold you up this is a pic with a 2.5 z and no cup with slam bags
pharcyde05 is offline   Reply With Quote
