Headlight Relay Install
Those of you that did the headlight relay install where did you mount your relays? Post pics if you got em.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: Headlight Relay Install
I don't have a picture, and couldn't get one to turn out very well if I tried, but if this explanation doesn't do you, let me know and I will try.
I mounted mine (along with two fan relays) on the back side of the core support on the driver side down by where the inner fender bolts to the core support. It was a tight fit, but it was out of the way. There was a flat spot that fit all four relays nicely. |
The Older Generation
TOTY 2006
![]() Join Date: Dec 1999
I too don't have a picture, but I mounted mine on the core support, behind the battery tray, and with the battery in place, you can't see them. I also made a plastic mounting the plate that all of the relays are screwed onto and then used one of the existing bolt holes on the core support to mount it.
John
How did you run your wires on yours?
TOTY 2006
I ran all of the wiring so that it looked like it was stock using the wire gutter along the top of the core support.
I will get some photos tonight when I get home.... |
Thanks John. I appreciate that.
Out of the carpool lane.
Here's how I've mounted mine. Looks like a mess that I need to cleanup.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
TOTY 2006
Here are the pictures of mine. They are hard to see, but hopefully you get the idea...
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by John Fabris; 12-22-2006 at 12:45 AM. |
John
Yep I see those. Got some more questions for you. Is your wiring new? Also have you noticed if that wiring gets any hotter since you are pushing more through it?
For the heck of it I took my multi meter out and measured the voltage on the driver side headlight while on high beam I got 13 volt reading from it. And 14.10 out of the alternator. Also I did install a new headlight and engine wiring harness about 6 months ago and I noticed when I installed it that the wires seemed to be 1 guage thicker.
#12 | |
Designated A-hole!
I used the relay box out of a dodge dynasty and used the installed relays. I mounted it in place of the voltage regulator, it blends in well with the core support and has spots for 9 relays.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
TOTY 2006
skokie, I did use a new wiring harness, E-Z Wire, and instead of the wires from the lightswitch/high-lowbeam to the lights, those wires run to the new relays, and then I had to add new wires from the relays back to the lights.
I have not really tested whether they get hot or not... but I am running a bigger gauge wire from relays to the lights.. |
