Old 12-24-2006, 06:29 PM   #1
sjarrett71
sjarrett71's Avatar
71 K10 speedo cable
I've shadetree mechanic'd most of my life but I have got something I've never seen before so I thought I'd ask. When I replaced my speedo cable, I noticed another very short cable attached to some sort of mechanism with 2 wires coming off it. The longer speedo cable from the speedometer screwed into the mechanism that was attached to the short cable and the short cable screwed into the transfer case. Will someone tell me what the short cable and mechanism is with the two wires attached? Do I need it? What does it do? Did I explain it good enough??
-Scott-
sjarrett71 is offline   Reply With Quote
Old 12-24-2006, 10:24 PM   #2
gator2511
gator2511's Avatar
Re: 71 K10 speedo cable
Sounds like the signal generator used with a Gear Vendors Overdrive tranny. Does it have a built in bracket to secure it to the frame? If that is what it is you don't need it unless you have the GV od unit.
gator2511 is offline   Reply With Quote
Old 12-24-2006, 11:48 PM   #3
sjarrett71
sjarrett71's Avatar
Definately not aftermarket overdrive. All I have is the tranny and transfer case. There are no brackets other than the crossmembers. I didn't track the wires but will. If someone will walk me through poisting pictures I will take a pic and post it.
-Scott-
Old 12-25-2006, 12:44 AM   #4
FarmTruk
In Memoriam...
FarmTruk's Avatar
Link to thread about posting pics...
http://67-72chevytrucks.com/vboard/s...d.php?t=220463
Good luck with the wiring.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-12-2007, 10:58 PM   #5
Brad
Out of the carpool lane.
Brad's Avatar
Bringing this to the top. I have a Jeep speedo cable that I'm using on my truck that has the same thing. I'm really curious as to what it's for. I was thinking that it might be for an electronic speedo hook up?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
