Old 12-25-2006, 07:42 PM   #1
Gene Sharp
top chop
I have what I think would be an interesting project idea for someone wtih mechanical drawing ,,,,enginering skills etc
A set of scale drawings with measurements for a top chop (say 4 ")
on Early and later 50s chevy trucks
Would be a real help to have some measuremts
and thoughts on doing it
there is a really neat top chop in the front of the Classic Chevy & GMC Truck parts catalog
Gene
Gene Sharp is offline   Reply With Quote
Old 12-28-2006, 07:44 AM   #2
desertrat
desertrat's Avatar
Re: top chop
I think it would be very difficult to make a set of plans for a 50's chop top. Once you start cutting the top, nothing wants to fall back into place as you would think. that's when you start getting creative ( cutting pie shapes, shaping and forming metal etc.....) . It's almost an art.
desertrat is offline   Reply With Quote
Old 12-28-2006, 12:43 PM   #3
Gene Sharp
Re: top chop
I have read a number of articles on chops
one suggested doing the doors first cutting off the top of door frames down at the bottom of where you want to remove the section
Then cutting the top piece and adding in from a donnor door
enough metal fo make it match the bottom half
Gene
Old 12-28-2006, 04:48 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
Re: top chop
And worse case is you end up with a convertible................
Brian ....
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-28-2006, 06:15 PM   #5
desertrat
desertrat's Avatar
Re: top chop
I started chopping my '41 chevy, I can't see doing the doors first. but than again I'm sure there are tons of ways to go about it.
Old 12-28-2006, 08:57 PM   #6
Gene Sharp
Re: top chop
looks good did you have to add some into the top of cab to make it fit after being lowered
Gene
Old 12-28-2006, 06:34 PM   #7
AesC10s
Chevy truck addict
AesC10s's Avatar
Re: top chop
Looking good desertrat
AesC10s is offline   Reply With Quote
Old 12-28-2006, 09:52 PM   #8
caino59
Re: top chop
as someone who has chopped a 59 chevy pickup (no small undertaking)
i can say without doubt the first thing you want to do is get your windshield cut before you start cutting metal.
you then cut the roof and build the roof around the glass, cutting and whatnot as need be.
then you do the doors.
the thing is - you can re-do any metal work....cut it, weld it, whatever.
but you can make glass fit a set opening very easy after the fact.
trust me.
1959 Chevy - Project Pics!
caino59 is offline   Reply With Quote
