Old 12-26-2006, 09:38 PM   #1
LawMan02
Junior Member
LawMan02's Avatar
Window rattle kit
I need to replace the rubber seal on the side windows and I think it's called a "rattle kit". It's rubber on the outside of window and felt on the inside. Anyway the question is what does it take to remove the old ones? Do I have to remove the window or does it roll down enough to take the old ones out. Do I need a special tool? Are there better kits than others. I have seen one lit that says it is "beaded" whatever that means. Thanks for any info. Randy
1972 GMC K2500, stepside, stock 350, 4 speed. Former F/D truck with 32,000 miles, no rust.
1973 Jeep CJ 5, 304, 33's with side pipes
2008 GMC 2500HD, CC, SWB, D/A, SLT
LawMan02 is offline   Reply With Quote
Old 12-26-2006, 09:56 PM   #2
Sweet72
Sweet72's Avatar
Re: Window rattle kit
There are half a dozen little spring clips (part of the rubber and felt wipers in the kit) that lock into small slots in the door. With a small screwdriver you can release the clips one at a time. Take careful note how the clips are attached to the door before removing so you get your new ones installed correctly. It's easy to bend the crap out of the wipers as your frustration escallates, so be careful! I have only done this with the window removed.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-26-2006, 09:59 PM   #3
jimmydean
jimmydean's Avatar
It looks like you might be able to do it with the window in, but I haven't installed mine yet. I got the kit from GMC Pauls and looks real nice.
I hope I won't have to pull the window because I will have to wait for the "dry" season to do it otherwise.
jimmydean is offline   Reply With Quote
Old 12-27-2006, 04:11 AM   #4
Aarons72s
I have done them with the window in. All the one's I have installed seemed to long so I trimed them with bolt cutters, quickest and cleanest way to trim them. Ive done it acople of times this way and haven had any problems. I agree with sweet72, I use a couple of small craftsman screw drivers to pop the old ones out. I usually use a 2x4 and a hammer to help pound the new one sin place, it keeps from hurting the fuzzies and the paint. As sometimes they dont like to go in very smoothly.
Aarons72s is offline   Reply With Quote
Old 03-16-2014, 02:45 PM   #5
jondancer
So this can be done with the windows in ? Mine really need replaced
jondancer is offline   Reply With Quote
Old 03-16-2014, 02:53 PM   #6
Lee H
Lee H's Avatar
Yes, can be done with windows in. Just pop off with a small screw driver and push back in with the heal of your hand. Once you get the new ones you will see how they are attached. They are so easy to remove & install you will wonder why you waited so long.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
