Old 12-27-2006, 02:19 AM   #1
truckdude239
truckdude239's Avatar
parking brake question
out got a quick question on my parking brake you use to be able to set the brake it and would lock the pedal automatically it stopped doing it i now got to reach under there and push the little lever to hold the pedal is there a way to fix this without replacing the hole thing?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-27-2006, 03:23 AM   #2
MisterMan
MisterMan's Avatar
Re: parking brake question
the return spring broke or somehing siezed. get stiffer spring.... or lube it.. pics?
MisterMan is offline   Reply With Quote
Old 12-27-2006, 08:18 AM   #3
GMCBubba
GMCBubba's Avatar
that same thing happened to me. the whole mechanism was frozen. wd-40 and some tlc sure helped. now i have to fix the rear brakes so the parking brake lever can do something
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 12-27-2006, 11:25 AM   #4
truckdude239
well the park brakes work i can reach under the dash and press the little lever that hold the peda; so i am thinking the spring is broke
David fuller
2000 Tahoe 5.3l 378
