Old 12-27-2006, 01:59 PM   #1
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
Anyone gone to the Borgeson Steering shaft?
I am being very particular with my burb and am not settling on how it handles and drives. I totally fixed my body roll problem with the front swaybar and Bilsteins.
So, my next little pet peave is the steering; I have dual stabilizers, a new rag joint, the weld in steering box kit, and the suspension and steering components are in good shape. There is a bit of wander in the steering wheel that I want gone. I don't know if I am being unrealistic. I know it won't feel like a rack and pinion setup, or even like a stock truck right off of the assembly line.
I called BDS suspension and a few local shops and the consensus is that the superior to stock Borgeson shaft will fix my issue.
I just wanted to put a feeler out and see if anyone has bolted on the shaft and what the outcome was.
Thanks!
88 Suburban
Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear,
Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more
redz 1970 K5 is offline   Reply With Quote
Old 12-27-2006, 05:40 PM   #2
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: Anyone gone to the Borgeson Steering shaft?
Weld-in steering box kit?
-- Will
killthewabbit is offline   Reply With Quote
Old 12-27-2006, 06:04 PM   #3
redz 1970 K5
OBS guy
Heck ya! The 73-87 4x4s are notorious for cracking the frame around the steering box mounts. This is highly accentuated by oversize tires.
Warrior products makes a 2 piece weld in kit to strengthen that very weak area of the frame.
88 Suburban
Old 12-27-2006, 07:35 PM   #4
killthewabbit
I'd heard of a cracked frame right around the steering box, but I didn't realize it was common enough to have it's own kit made to correct it.
Cool!
-- Will
Old 12-27-2006, 07:44 PM   #5
7T7
Regular guy
7T7's Avatar
I had a lot of slop in my old steering shaft on my 77.
It was this part circled in red that was bad.
After being unable to find one at the salvage yard any better than the one I had, I bought a Borgeson.
It's far superior to the stock unit.
'Frank'
77 Silverado
18 & 20 American CL205s
Edelbrock MPFI, 700r4, Baer Brakes
9" F@rd rear, Vintage air, Bags etc etc..
7T7 is offline   Reply With Quote
Old 12-27-2006, 08:59 PM   #6
magnethead
7000 #'s of american IRON
magnethead's Avatar
That is also what is bad on mine (aside from having put the wheel on about 15 or 20 degrees off of center when replacing the column). Are there any other alternatives as to fixing that very UGLY joint system that GM uses?
magnethead is offline   Reply With Quote
