01-03-2007, 03:18 AM | #1 |
Vintage Air temps
is there an ambient temp sensor in the Vintage air system? I just got my truck outta the shop and tried the a/c... the air didnt get cold and after asking him what was up he said something about an ambient temp sensor and that because it was like 60 outside the a/c wouldnt blow colder then that... sounds like a load of b/s to me, but thought I'd run it by "the pros" on this forum.
'67/70 Chevy C/10 '10 2500 Crewcab Duramax 4wd |
01-03-2007, 09:55 AM | #2 |
Sleep-Deprived
Re: Vintage Air temps
I'd check with Vintage Air for an answer. Seems like you'd see 40-50 degrees or less at the vents if you've got it set on the coldest setting?
Following that line of reasoning: So if it's 90 degrees it won't blow any colder than that?
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
01-03-2007, 03:34 PM | #3 |
If you have a "sure-fit" system for our trucks, there is a temp sensor in there somewhere, but it's not for ambiant temp. There is also a knob under the far right side of the dash to make it get colder before the A/C clutch lets off. In my truck, even at 35 degrees outside the Vintage Air system will blow colder.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-06-2007, 06:26 PM | #4 |
so vintage air is the best to purchase?
Central Florida in a black truck in the summer is tough. I'll be getting one before then. |
01-06-2007, 08:56 PM | #5 |
its just $$$$$
Its BS...it should blow cold regardless of the ambient temp. Which system is it. I have installed several and never had this problem, their product is top notch.
01-06-2007, 10:42 PM | #6 |
There is not an ambient air temp senser. Need to check the adjustable thermostat setting (full clockwise the back off 1/8 turn). If that checks ok, check the heater valve operation and make sure the hose past the valve is cooler than before the valve (between engine and valve). If that checks ok, we would need to know the low and high side head pressures - very common problem that it could be overcharged if installer not familiar with the proper charging procedure for the VA systems.
You can download a installers guide and trouble-shooting guide from the "Download" section off the Vintage Air web site. If you have any questions, call me next week during buisness hours - 1.800.862.6658 ext.111. Mark Tech Support - Vintage Air |
