Old 01-03-2007, 03:06 PM   #1
jlaird
jlaird's Avatar
Will these wheels look right?
I finally found a set of rims I like, but i'm not sure about the backspacing and if they are going to look right.
Here is the info. The wheels are 22x9.5 inches. They have a +25 mm offset. 25 mm is just about 1". So if my math is correct, that means these wheels have a 5.75" backspace. Now I have a 69 c10 that, if I get these particular wheels, I will be converting to 6 lug disk brakes. Remember that the 69 and lower rearend is a little narrower than the late 70 up. So, will these rims sit in the wheelwells correctly? My truck will be bagged so the rims will be tucked. What do you think?
Oh, one more thing. On the wheel spec sheet, there is a spec labeled "ET" and "VS" Does anybody know what these abbreviations mean?
Thanks for any help!
Josh
jlaird is offline   Reply With Quote
Old 01-03-2007, 03:28 PM   #2
pkj
Re: Will these wheels look right?
i may be wrong but my understanding is when you change front from drum to disc brakes the wheel will be moved out-board 1 inch. maybe someone else can chime in and verify this.
pkj is offline   Reply With Quote
Old 01-03-2007, 03:40 PM   #3
bretcopsey
I can't really answer your questions but I have found this site to be helpful when comparing offset to backspace.
http://www.rims-n-tires.com/info_spe...20/%20Comparer
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 01-03-2007, 05:41 PM   #4
smbrouss70
smbrouss70's Avatar
That's a cool site, thanks for the link!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-03-2007, 09:43 PM   #5
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I think he is right, hence the reason quite a few of us are running spacers out back. I am running 1-1/2 spacers out back.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-04-2007, 01:00 AM   #6
smoked68
smoked68's Avatar
If possible could you post a pic so I can see where your wheel ended up in the back after you spaced it. I am about to get the 1.5 and would like to see what it looks like. Thanks
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 01-03-2007, 06:19 PM   #7
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-03-2007, 09:25 PM   #8
jlaird
jlaird's Avatar
can anybody comment on what pkj said?
Old 01-03-2007, 10:47 PM   #9
jlaird
jlaird's Avatar
maybe I am thinking about this backwards, but wouldn't the wheel be moved in-board after a drum to disc conversion which is why you are using a spacer to move it back out?
Old 01-04-2007, 01:02 AM   #10
smoked68
smoked68's Avatar
He is not using the spacer on the front wheel he is using it on the back...I did a 6 lug drum to 5 lug disc conversion about a year ago but dont remember if it moved it outward or not. If it did it wasnt too much. Maybe an inch.
Old 01-04-2007, 04:50 PM   #11
BigSky71
LAIDOUT
BigSky71's Avatar
Josh
Do you have to order the same BS for front and rear? Some people are using spacers because the wheel size and BS that fits the front isn't wide enough at the rear, aesthetically speaking.
Before you pull the trigger on the wheels I would do some measuring or make a drawing. I installed a shorter rearend in my truck and have measured for the new wheels, but I also did a CAD drawing to see what my wheel dims should be. I don't remember the stock width of the early rearends so I guessed at 64". Some of these dims are from memory so I can't say they are absolutely correct.
The drawing shows the wheel and tire I already had drawn, 20x10 with 295/45s.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 01-04-2007, 05:06 PM   #12
jlaird
jlaird's Avatar
thanks for the help man. It's kind of hard to do measuring at this point because the bed needs to be cut to sit over the notch, and I have no brakes on at this point. I think I have found a new wheel though. It's what I originally wanted: clean 5 spoke design in chrome. They are 22x9.5 and I'm going with a 285-35-22. The wheel has a 13mm offset. I think that works out to be a 5.7" BS.
Old 02-27-2009, 04:44 PM   #13
BigShoe24
True Addiction
BigShoe24's Avatar
Does anyone have any tips for measuring? Anyone ever cut a piece of card board out in the diameter of the wheel, and measure?
RCC
BigShoe24 is offline   Reply With Quote
Old 02-27-2009, 06:23 PM   #14
SCOTI
SCOTI's Avatar
I always try & use a wheel of known size that fits & then caculate my required measurements from there. Wood makes for easy spacers to add width or height where required.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-27-2009, 06:43 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
This is a handy chart that I have saved to my favorites.
Keith
Convert to disc brakes.
Old 02-28-2009, 10:26 PM   #16
aggie91
I'm just glad to be here!
aggie91's Avatar
Keep one thing in mind when comparing OFFSET to BACKSPACING...
Offset is the amount that the center is offset to the front or back of the wheel when measured from the CENTER of the rim.
Backspace is measured from the OUTSIDE of the inner edge of the rim to the mounting surface of the wheel. The wheel dimensions (the width) is the distance between the tire bead surface and NOT the OVERALL outside width of the wheel. Typically the thickness of the bead area is about 1/4" for each side, so a 9.5" wide wheel would be about 10" wide on the outside edges.
That would work out to a 6" back space for a 9.5" wide that has a 25mm offset. That is shown in Lolife99's chart.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
