Old 01-04-2007, 04:35 PM   #1
ClassicRedneck05
ClassicRedneck05's Avatar
Exclamation Neutral Saftey Switch
can anyone twll me what wires go where because with my painless kit i have 2 purpal wires that already have the tips on it but i need to know where them 2 go and also i assume the 3rd one is for my reverse lights?
ClassicRedneck05 is offline   Reply With Quote
Old 01-04-2007, 05:09 PM   #2
70GMCer
70GMCer's Avatar
Re: Neutral Saftey Switch
If the painless kit uses the same color code as GM, then the purple wires connect to the neutral switch. I can't remember what color the reverse light wire is....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-04-2007, 05:20 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Check this thread out. After the images load (it may take a while) scroll down to the second image. Right in the middle you will see the backup/neutral safety switch. It has two purple and a couple of green wires. Trace them out.
http://67-72chevytrucks.com/vboard/s...d.php?t=185665
LockDoc
Leon
Old 01-04-2007, 05:20 PM   #4
ClassicRedneck05
well im tryig to figure out where the 2 purple wires plug in on these prongs i have the colors
Old 01-04-2007, 05:39 PM   #5
cdowns
cdowns's Avatar
take a meter and the 2terminals that have continuity when the shift lever is in park and neutral are where the purple wires go// the purple from the ign switch goes to the left
