08-23-2002, 07:17 PM | #1 |
Nylon timing gear
Anyone know if a `72 350 engine has the nylon timing gear? The 72 I had with a 307 had the nylon gear and it flew apart at about 160,000 miles. I have about 145 thou. on this motor and I`m wondering if I should be thinking abouy changing the chain and gears. THANKS
08-23-2002, 07:48 PM | #2 |
Weapons Of Construction
Shotgun it. If it ain't noisy, it's probably nylon and getting ready to go south. Even if the gear is still good, the chain probably needs a rest.
I think you have to pull the front edge of the oil pan down to remove the timing cover, so it won't be quite as much fun as it could be...
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
08-23-2002, 08:58 PM | #3 |
If you have 145k on the engine yse I would replace the timming chane. You can pick up a double roller chain pretty cheapand you will not have to worry about the oil pump locking up from the nylon chain.
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
08-23-2002, 08:59 PM | #4 |
14.1 @ 96MPH
Do it. Hell, the nylon gear on my '70 let go at 90k or so.
Project1970 - LS1 Swap Complete! |
08-23-2002, 09:05 PM | #5 |
its all about the +6 inches
I've seen them go at 60K, I recomend tossing it.
08-24-2002, 05:22 AM | #6 |
My other Love
Some chevy gears that ive dealt with were just coated in nylon while other were nylon. Or in the case of my 77 chevy the 400 had steel gears (i was the first person to change the timing set). I would recommend changing it every 100 000 miles but i am also cheap and sometimes lazy
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
08-24-2002, 11:36 AM | #7 |
nylon gear
Thanks guys you talked me into it. When mine let go in the old 307 it bent some push rods and turned into a real job.I guess this is a case where you should fix something that isn`t broken...(yet). THANKS
