01-14-2007, 06:19 PM | #1 |
1972 Wheel and tire questions
I have a bunch of questions I hope you guys can help. I just got a 1972 K5 and I want to restore and redo a lot of things. One thing is I want to change the wheels and tires on it. It has a 33x12.5 on a 16.5 rim now. I want to get a bigger rim but i don't know the bolt pattern. Can anyone tell me what it is? Its a 4x4 also. And if I put it on 35 tire with 18-20 inch rim will there be steering issues or will it hit the wheel well? Will i need a lift kit or spacers? And if so how big? Last question is does it make sense to put a 20inch rim on or would i be just as good with an 18 if I'm mounting 35's on it? Thanks alot -Mike
01-14-2007, 06:24 PM | #2 |
Designated A-hole!
Re: 1972 Wheel and tire questions
The bolt pattern is the standard 6 lug used by GM on all trucks up to 71, and 4wd's from 71 to 87 (91 for blazers and burbs). It's actually the same as the current GM 6 bolt pattern, but the new wheels don't have a center hole big enough to go over the hubs.
BTW Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
01-14-2007, 07:18 PM | #3 |
The LuvShack Garage
1st - From West TN
AND 2nd - If you want 35's you will need at least a 6" lift
01-14-2007, 08:28 PM | #4 |
Welcome to the site.You can put 35s on w/ a 4" lift but wheeling there will be rubbing
01-15-2007, 12:21 AM | #5 |
01-15-2007, 12:23 AM | #6 |
You should be able to get away with a 4" lift and 35s if its a daily driver
01-15-2007, 08:04 AM | #7 | |
The LuvShack Garage
Look at the pic's in my siggy link for "GQ" it has 35's and the front springs are 4" (The rear is 6" because the Previous owner wanted it level w/ the top on)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 01-15-2007 at 08:04 AM. |
01-15-2007, 01:43 AM | #8 |
SKINNY TIRES RULE!
Welcome to the board.
Some guys have had the center holes of newer style wheels machined out to fit over the larger hubs on the first gen blazers.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
01-15-2007, 11:12 AM | #9 |
Actually neither 20's or 18's make sense on a 4 wheel drive. Bigger wheels make for smaller side walls, and unless you plan on entering drifting compititions or road racing the only other reason to have big wheels is just for looks. So bigger side walls are better for 4x4's. Which means 15" wheels work the best when you are running 35's (and in my personal opinion look better as well). Hope this helps you out a little. Oh and welcome.
01-15-2007, 06:51 PM | #10 | |
Gotta Welcome to the board from VT. |
01-18-2007, 05:46 PM | #11 |
Global warming is a myth
X2
Plus, I've heard the "unofficial rule" for sizing wheels & tires is that the wheel should be NO MORE than 1/2 the overall diameter of the tire on a lifted 4x4. In your plan that would mean that you only go to 17"s, which wouldn't be bad, BUT I still agree with VT & desertrat. Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
01-18-2007, 05:55 PM | #12 |
Just an FYI, on my Mall Crawler I have 33x12.50x20" Nitto Mud Grapplers on Helo Maxx6 with 5" back spacing, 72 K5 with a 4" kit. The 20" rim clears the steer linkage great, where a 16" wheel with 4" is very close. Extreme turing in a tight flex situation the drivers tire rubbed the back of the wheel well. Love the set up, tires a great despite their Cessna Sound going down the road. Got mine for just riding to the beach and such, so take aything I say with a grain of salt.
01-18-2007, 06:02 PM | #13 | |
