![]() Join Date: Aug 2006
Is this going to mess me up?
I bought Rokcrlns plans for the tip and flip dolly. I am just about done building it. I was thinking. While the cab is on the dolly would it be bad to replace the rockers, maybe the floor, design and install a new dash? I am worried about things not alligning the same once they get reinstalled on my frame. I hope that makes sence. I just wanted to know how much i could safely do without things aligning different. Thanks alot!!
Josh
(Project truck) 1970 C10 under complete transformation ![]() My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
Re: Is this going to mess me up?
I would think it would be easier to do some sheet metal replacement off the frame. As long as you're not touching the mounts, you're fine.
If you do have to touch the mounts or anywhere that might affect it, measure before/during/after and you're good to go. |
If you are gonna cut on it most anywhere, then it needs to be bolted back to the frame ... even then it's a good idea to weld temporary bracing in.
#4 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
So even for just replacing the rockers i should bolt it back on the frame? I would agree for replacing the floor if i have to do that. What about removing the dash and building a new custom one. Do you think that will be okay? Thanks alot for the help.
Josh
BlahBlahBlah
Why dont you PM Rokcrln and ask him how he uses his. I have the plans somewhere...do you bolt it to the dolly using the body mount holes? If so I would think that would be close to the same as having it bolted to the frame. Bracing the door opening does sound like a good idea though.
#7 | |
Josh
*Yes that is a great idea! Here is what I answered then I saw this thread so I thought I would let eveyone know what I sent.*
This is just what it is made for. As long as you take your time and follow the steps you will end up with a perfect platform for this kind of work. I designed the dolly to be set at the factory heights for body mounts (w/o bushings) and flat so it will keep it all lined up right. From what I have seen of your work this should not be a problem for you at all. Kevin LFD Inc. |
