Old 01-20-2007, 03:16 PM   #1
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Power Steering mounting problem?
I hope the pics are good enough but can anyone tell what's mounted wrong? I can not get the cap off my power steering pump. It hits the alt bracket. Something isn't right but I don't have anything to compare it to.
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 01-20-2007, 03:25 PM   #2
speedracer
Blank
speedracer's Avatar
Re: Power Steering mounting problem?
My vette came from the factory like that, don't know why but it's stupid.
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline   Reply With Quote
Old 01-20-2007, 03:29 PM   #3
rage'nrat638
rage'nrat638's Avatar
HERES WHAT I HAVE RANDY!!!!
I AM OUT IN THE GARAGE NOW I CAN TAKE MORE PICTURES IF YOU NEED..
opps sorry about the caps
looks like you have the 71=72 model power steering pump bracket... mines a 69 wonder if you install a longer belt if it would lay back more and clear the alt bracket?
rage'nrat638 is offline   Reply With Quote
Old 01-20-2007, 04:51 PM   #4
Draggn66
Draggn66's Avatar
Hey Mark....yea I was kinda thinkin I might try the longer belt thing when I put the crank pulley and new belts on for the Vintage Air install. From what I've seen it looks like I have the correct brackets. Thanks for the input!
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
Old 01-20-2007, 04:56 PM   #5
ghackett1
68 C10 Longbed
ghackett1's Avatar
How about using a shorter belt that would move the cap over enough to turn it, Maybe?
ghackett1 is offline   Reply With Quote
Old 01-20-2007, 05:03 PM   #6
rage'nrat638
Thumbs up Re: Power Steering mounting problem?
yea no problem randy... and after looking at your pictures real hard check out the slot in the rear of the pump for adjustment..looks like your almost all the way adjusted out..? hard to tell.. maybe a smaller belt would make the cap clear the alt bracket? something to check out
should be some solution to this delima !!!!
sounds KOOL on the vintage air set-up.
make sure you take pleanty of pictures as you could do FAQ on the install
sure there would be plenty of members that could use that..
we will have to hook up soon..your pal mark
Old 01-20-2007, 04:05 PM   #7
sjarrett71
sjarrett71's Avatar
If you don't have A/C just move your alternator to the other side.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 01-20-2007, 05:01 PM   #8
Draggn66
Draggn66's Avatar
Anyone know the correct(factory)length of the ps belt? or pn#?
Randy
Shorewood, IL.
1971 C10 Longbed
2005 FXDWG
