~Rest In Peace~
need help with powersteering pump
im trying to mount the powersteering pump on my 70 gmc truck i got the bracket that bolts to one of the motormount and 2 bolts on the front of the engine but i cant get it to adjust up even when all bolts loose it moves about 1/4 inch any one have pictures to check out and the altenator is on the same side (drivers) altenator is above the p/s pump and 350 cid
help
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex Last edited by fastwillie 696969; 01-22-2007 at 07:37 PM. |
![]() Join Date: Aug 2003
Re: need help with powersteering pump
Did you loosen the nut on the back of the pump? You can also try loosening the bolt that runs through the bracket. It's located towards the bottom.
the first picture is my 69 350 p/s bracket
the second picture is a 71 p/s bracket post pictures of your brackets Last edited by rage'nrat638; 07-12-2007 at 06:58 AM. |
~Rest In Peace~
hey rage where did you get that bracket mine doesnt even look like that
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#5 | |
the top one is the stock 69 bracket..on my engine the bottom one is a stock 71-72 bracket biilsbowtie has or had forsale thats why i kept the picture..they are different mines one piece in the front, and the other is two piece in the front... |
