Old 01-24-2007, 12:10 AM   #1
Cochise
Junior Member
Cochise's Avatar
Would LIKE to buy, but gauging prices...
I really need Shock Relocators for my '70 Chevy. I can get them for about $80, but would like to pay MUCH less. I also would like to know about how much it would be to get either a Posi rear-end or get my open rear-end set up as posi, and still be able to turn a corner without bouncing around everywhere.
located Rogers, Arkansas 72758
Cochise is offline   Reply With Quote
Old 01-24-2007, 08:54 AM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Would LIKE to buy, but gauging prices...
To change your rearend over around $200.00 labor + what ever parts you need.
Posi unit, gears, Axle bearings, carrier bearings, lube, additive, ring & pinion and labor will set you back $1200.00
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-24-2007, 08:55 AM   #3
70c10
67-72 Addict!
70c10's Avatar
classic performance parts has a deluxe shock kit (4 lowering shocks) including relocators for about $169. Not a bad deal considering shocks are $40 each. I bought my Eaton posi for $280 from Tomsdifferentials.com about 4 years ago.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-24-2007, 11:31 PM   #4
Cochise
Junior Member
Cochise's Avatar
Thanks for the answers. I have already had the truck lowered, just missing the relocators
