01-25-2007, 12:21 PM | #1 |
Gearbox "lock to lock 3 turns"
Does anyone know what year model (71 to 87) Chevy truck or van powersteering gearbox had three turns lock to lock that would fit my 71 C-10.
01-25-2007, 12:51 PM | #2 |
Out of the carpool lane.
Re: Gearbox "lock to lock 3 turns"
Mine is from a '77.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
01-25-2007, 01:07 PM | #3 |
I've been looking at the boneyards and all the trucks I've found are missing the P/S box. But I did locate a 78 Chevy van which I bought my tilt column from. Will the van P/S box work or is it strictly just a truck gearbox.
01-25-2007, 03:04 PM | #4 | |
You'll need to swap out your pitman arm with the one on the van box. Other options would be S-10 and cars. Alot of them use the same Saginaw steering box as the older trucks but they might have different internal stops and the newer ones will have different style fittings for the hoses. I just put a Monte Carlo box on my wife's 95 S-10 Blazer last night, and I have one off of an IROC Camaro on my S-10. The Camaro box on my S-10 steers great but it won'tlet it turn as short as the original box would.
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
01-25-2007, 03:22 PM | #5 |
Thanks for the info! I'll have to really look into the mounting of the box. Hopefully I can find a box soon,,,,,,It sure is hard to shift gears "3spd" on the column and make a sharp turn with no power steering.
...try'n to be a little! This is a great site. http://67-72chevytrucks.com/vboard/s...d.php?t=157669 http://www.67-72chevytrucks.com/vboa...d.php?t=375640 |
01-25-2007, 02:24 PM | #6 |
Don't know if this helps but we replaced the leaky PS gear on our 71 C20 with a unit from a 78 c10, the 78 unit does require less turning lock to lock than the original did.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
01-25-2007, 03:00 PM | #7 |
Thanks,,,,,I,ll keep checking the salvage yards until I find a 77 or 78 with three turns lock to lock.
01-25-2007, 03:51 PM | #8 |
Get the rag joint with the box, the shaft size changed some year in there, the old rag joint won't work.
01-26-2007, 01:02 AM | #9 |
I threw one on from a 74' . Bolted right up and was the right length with the right rag joint and pitman arm. The original should have the same internals up to 76'. Reman part #'s change in 77'.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop |
01-26-2007, 06:06 AM | #10 |
Weekend Warrior
I don't think a Van box will work - input shaft has a differant angle than a regular truck I believe, but don't quote me on that.
If you don't have power steering, why not just get a P.S. box from a '73-87 truck with the Pump, Lines, and pulley set up. You will probably have to change your waterpump to the later long style to configure with the later pump/pulleys. Get the Alt. Braket as well - as that will change. Not as hard as it sounds and then you don't have to worry about strong arming it while worrying about shifting Just a thought
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
01-26-2007, 02:55 PM | #11 |
Input angle would be different on a van but only because the entire box is tilted.
The long waterpump style brackets and pump will definately be easier to find. You could get the pump and brackets off of a van also, (as long as it's smallblock powered), but the lines probably won't work.
01-27-2007, 08:08 PM | #12 |
Thanks for all the info,,,,,the van P/S ox will not work due to the angled connection. But I did find a P/S box from a 1977 C-10 with three turns lock to lock. Thanks for all the info!!!
