Old 01-25-2007, 10:29 PM   #1
Bowtie468
Bowtie468's Avatar
Interior pic needed !! ( Carpet )
Could someone provide me with a pic showing how far the carpet extends towards the front and rear of a 67-72 p/u cab ? Thanks !!
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 01-25-2007, 11:22 PM   #2
matthufham
Re: Interior pic needed !! ( Carpet )
typical trucks, i don't know
my truck however has carpet all the way up on the front to about the gas pedal on the firewall, carpet on the kickpanels, carpet on the back wall, and i welded the cab corners shut and put a speaker on each side so carpet covers that too.
matthufham is offline   Reply With Quote
Old 01-26-2007, 01:39 AM   #3
bs25j
bs25j's Avatar
I took some pictures but their not working. The carpet I have goes up to the holes for the heater box on the passenger side and about an 1/2 to an inch below the hole for the steering column on the driver side. In the back it is a little bit past the door. When I had the gas tank back there it tucked under about an inch.
Ill keep trying to get the pics working.
bs25j is offline   Reply With Quote
Old 01-26-2007, 01:48 AM   #4
bs25j
bs25j's Avatar
There you go.
Old 01-26-2007, 11:29 AM   #5
Bowtie468
Bowtie468's Avatar
bs25j, although i can't see the pics (red x's), i can visualize how much it covers by your description. Thanks a bunch !!
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 01-27-2007, 10:21 AM   #6
Yukon Jack
Yukon Jack's Avatar
When you order your carpet you can ask for it to be left long so it definitely extends to the back of the cab. Tim Christian did that for me when I ordered from him.
Here are a couple pics.
I bought mine extra long so I could make this covered piece for the back of the cab.
With the remaining carpet I then went in and filled in some of the under dash areas that were somewhat visible. Turned out very well but I don't think I have a good pic showing the under dash area after I added the extra carpet.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
