TH 400 KIck down?
hey all.....i want to have my TH 400 have the "kick down" option on it so what all do i need to buy or get for this to happen..i wanna be able to floor it and feel that tranny drop back to second than chirp into third...GONNA HAVE TO GET A BIGGER POWERPLANT THOUGH
i think i found me truck! 78 Crew Cab Dually 454/TH400, Dual Flows, Edelbrock Intake, Cam, Lifters, Billet Grill, K&N Airfilter, Grant Steering Wheel, A/C, soon to be power windows and locks, lots of plans for this... ....gas prices go down please |
You will need the kickdown switch, for mounting on your carburetor, bracket for a Holly or Q-Jet, (to fit the carb that you have on your engine), tab to mount on the throttle, and the wiring. I would suggest that you post on the parts wanted board
for the setup. The described setup is for a 69 which it appears that you have. 71-72's are different. Jim |
![]() Join Date: Dec 1999
i just changed from a 400 to a 700r4 in my truck and still have the kickdown switch and maybe the oakey rigged tab that i attached to my throttle plate to activate it. pay shippin and its yours. email me if your interested
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
![]() Join Date: Sep 2001
I just went through this process trying to find a kick-down switch for my TH400 for a 2bbl carb. Luckily its easier to find for a 4bbl. Here's a picture of what you're looking for for different carbs.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
I have a th400 in my 67 with no kickdown switch. It only has a vacume hose going to the manifold. It seems to me that it kicks down like it should. How can this be?
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
sweet
Gabet....do you know if it will fit my carb, holley 650 (4175)(POS)...its in the rebuild prcess so hopefully no P.O.S.....anywho..do you know if it will?......thanks for the offer!
![]() PAW carries a Lokar switch and you can still buy the bracket from your chevy dealer.
69 C10 lwb, 400 sb, Turbo 400, |
Jwill41: Yes, it will still kick down but pretty rough, and you'll have to hammer the gas to do it. The 400 regulates shifts based on rpm, fluid pressure AND whether or not the detent circuit is activated (current is getting to the detent soleniod inside the pan). You're missing the third element which makes everything much smoother.
Mine would kickdown, but it always felt like I was jamming the damn thing into 2nd. After I installed that detent switch on the carb (thanks to breeh) it would pause for a fraction of a second, then smoothly slide into 2nd, which is what its supposed to do with stock valve body. And that's without having to hammer the gas. Either way its good to have one.
Oh yeah, and another thing. PICKMUP suggested Lokar when I was trying to find an aftermarket switch. They look like they have a damn good setup for 4bbl-to-400 detent switch. The switch actually bolts to the transmission, and a cable activates the switch from a bracket on the carb. Nice and clean without the switch on the carb, but it looks like $$$ because it's all stainless.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. Last edited by COBALT; 08-26-2002 at 05:08 PM. |
Old Skool Club
![]() Join Date: Jun 2001
The Lokar switch actually mounts at the transmission, with the cable from the carb acting as the actuator. The cable has to be cut to length.
As for operating (kicking down) without any actuator, it is being done by vacuum, or actually a lack of it. I had my valve body modified (no shift kit) and the modulator valve was changed to a little ole bitty one. My tranny will kick down, but it is due to a lack of vacuum. I have the Lokar switch, but haven't installed it yet. Heck, I've only had the switch for about 2 years....what do you expect? I have kids and grandkids and no job and, aw what difference does it make? I'll put it in when I get good and ready and it cools off and it ain't raining and I'm not hungry and yada, yada, yada. The Lokar switch is a really clean item to have, if you can't get your hands on the original type or your carb has been changed and you can't use the original. Mine was removed when someone put on an Edelbrock 1405. I put an Edelbrock 1901. I may try to find an old switch and bracket.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
well my switch is for a four barrel but i had it on a quadrajet, and lookin at the photo of your carb on the holley website, they dont look anything alike. but the mounting has to be pretty similar right? i think itll fit.
like i said, you pay shipping and its yours, id be a lot happier with it there possibly puttin some good use to it than sittin in a box full of parts from my old 350 in the shed. speakin of good use, funny story to my kickdown switch, i didnt even know i had one until my electrical shop accidently connected it to my parking lights. so anytime at night, i would have to bring her up to about 3800 rpms to shift and didnt know what was goin on! once i straightened it out, boy thats a nice switch
