Old 01-28-2007, 10:49 PM   #1
outlaw_69
outlaw_69's Avatar
TH-400 in 69 GMC 1/2 ton
The truck had a 3 speed on the colum, but uhh...im packin big power so i had to get a big nasty tranny. I've heard of needing to move the cross member back to get it to mount up. How far do i need to move it back? Thanks-
Greg
If it don't lope...well...it sucks.
outlaw_69 is offline   Reply With Quote
Old 01-28-2007, 10:58 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: TH-400 in 69 GMC 1/2 ton
You'll need to OBTAIN a cross member. The 3 speed has a totally different set up.
Old 01-28-2007, 11:04 PM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
For a TH400, you'll need the crossmember, the donor trucks driveshaft, the column, the shift linkages, the list goes on.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 01-28-2007, 11:11 PM   #4
Longhorn Man
rad, cooling lines, kick down switch (on carb) and wiring, and the hard line for the vac modulator.
