Old 01-29-2007, 07:55 PM   #1
rick0312
rick0312's Avatar
Oil filter Question
I recently Id'd my engine and it turns out to be a '76 305. I have been using an oil filter for a 69 307, which is twice as long as the filter reccomended for the 305. Could this have caused any problems or damage to the block ie reduction in oil pressure etc.....what do you guys think?
thanks
rick
rick0312 is offline   Reply With Quote
Old 01-29-2007, 08:11 PM   #2
wheels67
wheels67's Avatar
Re: Oil filter Question
Nope, your fine. Alot of guys change to bigger filters. As long as the oil was topped off.
wheels67 is offline   Reply With Quote
Old 01-29-2007, 08:32 PM   #3
cooters
i use a 3 ton oil filter which is about a foot long, better filtering a possibly a little better oil cooling. If it fits then bigger is better. Big filter is Fram ph373
cooters is offline   Reply With Quote
Old 01-29-2007, 08:38 PM   #4
jacobs
jacobs's Avatar
This is a GREAT filter. It holds 2 quarts of oil. I've been using it for many years. I have only one complaint....it costs about twice as much as the one quart filter.
jacobs is offline   Reply With Quote
Old 01-29-2007, 08:36 PM   #5
dave2953
Dave's not here, man
dave2953's Avatar
I use the shorter filter on my truck, but they're interchangable.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-29-2007, 09:01 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
are you guys really putting fram filters on your trucks? They are the absolute worst filters on the market. Not opinion here.... fact.
Old 01-29-2007, 09:09 PM   #7
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: Oil filter Question
Yes FRAM = Death and Destruction to an engine!!!! It's the only filter that I know of that WILL VOID Factory Warranty on new Dodge and Chevrolet autos!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-29-2007, 10:08 PM   #8
jacobs
jacobs's Avatar
My engine has over 275,000 miles....all with Fram oil filters and still has a compression of 150, runs great, and the engine has NEVER been opened up. You can’t knock success! Rumors, rumers, rumers....I don’t believe them. Show me proof.
Old 01-29-2007, 10:25 PM   #9
GREASEMONKEY72
GREASEMONKEY72's Avatar
FRAM FOR LIFE!!!!
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-29-2007, 09:14 PM   #10
Longhorn Man
The dealer will tell you that, however, if they try pulling that on you, get it in writing.
Fram filed a lawsuit on that and won. If your dealer tells you this, then they are required to supply you a filter at no charge to you.
Fram totally sucks, and the OEMs hate them just as much, but don't let the dealer screw you over.
Old 01-29-2007, 09:23 PM   #11
dave2953
dave2953's Avatar
When I bought my 71 Dart the PO used Fram filters and complained about not having any oil pressure. He switched filters and it solved the problem. I guess the Fram filters are designed to filter really small particles and it greatly reduces oil flow?? That could just be jibberish, but it sounded good! I'll bet Longhorn Man knows.....
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 01-29-2007, 09:33 PM   #12
Longhorn Man
I can't explain that part of the equation, i have heard it before though.
Fram simply doesn't have enough filtering media in it. Think of it as a tin can with 3 kleenex tissues thrown in it.
Old 01-29-2007, 10:35 PM   #13
krue
Designated A-hole!
krue's Avatar
For proof go to www.bobistheoilguy.com . I know people who have driven furds and had no problems with them.....doesn't make me want to drive a furd.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-29-2007, 10:52 PM   #14
FarmTruk
In Memoriam...
FarmTruk's Avatar
I was always a Fram user until I was enlightened. I was SHOCKED when I saw the info on this website.
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
The info on the above site is geared to Mopar, but the analysis will be the same regardless of the car/truck.
Not all Fram filters are turds. The Fram Tough Guard was rated good, but with the really poor performance of the other Fram models, I'd still stay away.
This is MUST READ info...
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-29-2007, 11:10 PM   #15
rick0312
rick0312's Avatar
Thanks!!!
Old 01-29-2007, 11:22 PM   #16
faribran
...... so what is the BETTER filter??
faribran is offline   Reply With Quote
Old 01-29-2007, 11:34 PM   #17
FarmTruk
In Memoriam...
FarmTruk's Avatar
There are several recommended. This link is the 2nd page to the above link...
http://people.msoe.edu/~yoderw/oilfi...ilfilters.html
It give great details on recommended and ones to avoid, and why the recommendations are made.
FarmTruk Pics Here
Old 01-29-2007, 11:42 PM   #18
cooters
dealer filters are the best, i have had 2 filters colapse on the inside in high horsepower engines about 10 years ago, since then they seem to be working and i do check them. John Force wouldnt stear us wrong, would he?
Old 01-29-2007, 11:57 PM   #19
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
ive ben useing the fram ph5 and ph8 for 9 yeaers on multiple trucks and motors and never had a problem.
i have had a filter get slapped by a hedder and wear a hole in it but it was a tight fit and then it got bent wheelin.
trkklr77 is offline   Reply With Quote
Old 02-01-2007, 01:43 AM   #20
gmcman7202
Active Member
gmcman7202's Avatar
this is super great. posting a link to someone at my school, super interesting!!!!
gmcman7202 is offline   Reply With Quote
Old 02-01-2007, 02:50 AM   #21
GREASEMONKEY72
since we are on the subject of oil filters what about air filters to?? i mean we dont want someone to run the wrong airfilter to now do we??
-steven
Alte Seele S.S.
Old 02-01-2007, 11:07 AM   #22
Ole Blue 68
Ole Blue 68's Avatar
Here you go Greasemonkey...
http://67-72chevytrucks.com/vboard/s...t=paper+filter
Ole Blue 68 is offline   Reply With Quote
Old 01-30-2007, 12:54 AM   #23
Longhorn Man
all I'll say is this.. go get a napa gold filter (P/N 1060) which is nothing but a rebadged Wix filter, and cut it open... then cut open your beloved fram, and you will never screw another one onto your motor.
Yes, you can get 275,000 miles with fram filters.... we also got 265,000 miles on the original automatic overdrive in a ford F-150 in a fleet driven truck that had been abused and beaten... totaled 3 times, and only had the fluid chainged once at 95,000 miles. Anything can happen.
however, if you know what you are looking at... and even if you don't know, but just have common sence...crack open the 2 filters and have a look see. Go ahead, spend the 18 bucks to look at them yourself.
As far as John Force... even the Rolling Stones sold out. Money talks.
Old 01-30-2007, 01:52 AM   #24
skokie
skokie's Avatar
Glad I started using wix.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-30-2007, 03:31 AM   #25
1969 GMC
1969 GMC's Avatar
delco filters aren't bad either. should be a 1218 (1qt) or 932(2qt).
carquest's good filters are also made by wix.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
