01-29-2007, 08:03 PM | #1 |
Almost ready to give up!!!!! Help!!!
As I mentioned in my earlier post I rounded out the plug in the head for the temp sensor. Like an idiot I drilled a hole in the plug and tried to use an extractor to get it out. Could not get it to budge. I brought the welder home tonight thinking I could weld up the hole in the plug and things would be good to go. I can not get the plug to quit leaking. I dont want to damage my head but I don't know what other options there are. It would be wonderful to be able do the repair with the head still on but I think that isnt going to happen. I guess my only real option is pulling the head and taking it to the machine shop. Anyone have any advice?????
Thanks Jeremy |
01-29-2007, 08:21 PM | #2 |
Well, Whoop-dee-do!
Re: Almost ready to give up!!!!! Help!!!
Find a flatwasher with an ID just under the OD of the plug. Weld it on by filling the center. It's important to weld it in one step to get good heat & penetration. Let it cool a bit & weld a nut to it- around the edges of the nut- welding the center won't be strong. Let it cool and it should spin right out.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
01-29-2007, 08:24 PM | #3 |
Ouch
Do you have enough room to get oversized Wise Grips on it??? Get plenty of bolt ease liquid on it. Heating head will not help, since brass typically has a greater coefficient of expansion than cast iron. (I am assuming that you have cast iron heads!)
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
01-30-2007, 09:39 AM | #4 |
I think that I am going to try welding the washer and nut on tonight and see if I can get it out. I am getting a trace of antifreeze out of the first exhaust manifold bolt hole on the left side.....Is that hole part of a water jacket or shouldnt I be getting any at all???????
Thanks Jeremy |
01-30-2007, 07:27 PM | #5 |
Well, Whoop-dee-do!
Not sure why antifreeze is coming out of the manifold bolt hole. Can't remember seeing it on a SBC before. If there are no cracks running out from the hole, just clean the threads good & put plenty of sealer on it when you put it all back together. The end hole on small block Mopars is drilled all the way thru to the water jacket- you have to seal those. The first manifold I pulled on one of those as a kid freaked me out- antifreeze was shooting out on the wheelwell
