ROCKWELL 5 TON CLUB !!
![]() Join Date: Oct 2006
orig fuel tank??
this is the fuel tank that i pulled out of my 70k5.it is alum. and fit perfect between the frame rails.filler neck and vent in correct location.is this a factory tank?
![]() if i decide not to use it,anyone interested?whats it worth?thanks
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!" MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=221935 1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS HINT:NEW NAME "K5ontheROCKS!" |
Re: orig fuel tank??
NO. The factory tank has rounded corners and has a seam in the middle. this is an aftermarket tank either home made or ?? Nothing wrong with that ---so I would use it in a second as it is probably stronger then stock and if aluminum, lighter too!!
I agree with Huck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
The Blazer King
Definatly not stock. I Wonder if it holds more gas though. Looks to be in good shape.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
Future TOTM Winner
Yeah, do you know how many gallons it holds? Looks to be pretty well built.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
I Havent Driven The Truck A Whole Lot,basically Just Back From Florida.i Would Run The Gauge Down To E And Refill @ Around 18gals.im Not Sure What The Stock Capacity Is.the Tank Is Really Nicely Built And Solid,has A Baffle Inside Plus Like I Said The Vents And Fillers Are Perfect Fit For The K5.im Going With A Fi Setup On My Blaz.this Might Be An Easy Tank To Modify For Vents/returns Etc.well See.
#7 | |
USE IT! Thats a nice tank. Go to tanksinc.com ![]() They have in-tank pump tank kits, should fill the bill perfectly. Here's the link. http://www.tanksinc.com/cartimages/page_lg_24.jpg Last edited by vtblazer; 01-31-2007 at 07:06 AM. |
![]() Join Date: Jan 2007
Here is a stock one for the 70 K-5
I would take it and have it pressure tested.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
The LuvShack Garage
No, like others have said, but very nice, use it
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
