02-01-2007, 03:07 PM | #1 |
It's a catastrophic success.
Factory A/C conversion
This is a post for the FAQs. Thanks for the use of peoples pics for which this post could not be made possible.
I recommend using or at least have access to a donor truck for parts and reference. Lets start with the dash, You have a few options. 1. Remove the whole dash, by removing the side bolts and drilling out the spot welds around the windshield.This means you will have to remove the glass. 2.Cut the dash under the pad along the dotted line, This leaves the windshield portion untouched. Install the new AC dash and weld up and the pad covers the joint. 3. The less but not necessary the easiest, Make templetes and cut holes for the three AC vents. |
02-01-2007, 03:10 PM | #2 |
Re: Factory A/C conversion
It appears you did the cut and weld under the dash pad, if so, how did you handle the boxed ends where it bolts to the "A" pillar?
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
02-01-2007, 03:11 PM | #3 |
The firewall has to be modified here are the differences.
02-01-2007, 03:13 PM | #4 |
For the purpose of recirculation a cowl vent flap needs to be installed
02-01-2007, 03:53 PM | #5 |
Here is some tech on hose,wiring and vent routing.
02-01-2007, 04:02 PM | #6 |
Or you could just go here for an aftermarket to fit the original controls and vents.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
02-01-2007, 04:22 PM | #7 |
A couple of pics of the compressor and the brackets
09-14-2007, 07:45 PM | #8 |
Hey guys, I am researching how to complete the AC for my truck and came across this older post.
Correct me if I'm wrong, but the last pictures of the AC brackets look like two completely different bracket set ups. Is there a couple of correct brackets for our trucks? I think I have the set like in the lower two pictures and am hoping it will work on my 71 K20. |
09-14-2007, 09:34 PM | #9 | |
HERE.......Somewhere
All I have is the haeter and the fresh air vents in mine just wondering how it looks and how it works
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
09-14-2007, 09:38 PM | #10 |
This really makes me appreciate that my truck has factory ac.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-16-2007, 10:22 AM | #11 |
Old Skool Club
At this time, I believe, all I need to do is evacuate my system, add freon, intall a new drive belt and turn it on. I say this because I pulled the belt a few years ago. Oh, it needs a seal on the clutch side of the compressor....yeah, that's why I pulled the belt....that and I didn't replace it when I replaced the other belts.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-16-2007, 10:01 AM | #12 |
Old member
The top pictures are of a compressor that was mounted without the correct brackets. It works but not correct. Look at the front and back bracket they are the same one. The bracket on the back is correct.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-20-2014, 02:51 AM | #13 | |
My 69 CST/20 with 350, TH400, and A/C came new with the set shown in the top 2 pictures. Either set will work, but the brackets shown in pictures 3 and 4 are a lot cleaner setup. They also allow you to remove the valve cover without having to move the compressor and its bracket out of the way. That's a real PIA. Just ask me how I know. I have multiple detailed pictures of my brackets installed if anyone wants to see them. |
03-19-2014, 08:01 PM | #14 |
you all rock! thanks
