Old 02-02-2007, 12:37 PM   #1
isenegger
anyone put 3/4 ton coil on 1/2 ton?
i need to lift the front of my 2wd 1/2 ton about 2" or so. has anyone tried the 3/4 ton coil?
isenegger is offline   Reply With Quote
Old 02-02-2007, 01:30 PM   #2
66skylarkpost
66skylarkpost's Avatar
Re: anyone put 3/4 ton coil on 1/2 ton?
of what i remember in my moog spring books , theres a standard 1/2 set , and a heavy 1/2 set( air -bigblock )that was the same part as a stardard 3/4 , plus maybe a 3/4 hd ( air bigblock - 1 ton . a total three diff spring sets for the front , yet they will all interchange
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 02-02-2007, 04:40 PM   #3
70rs/ss
70rs/ss's Avatar
Yeah, you can put 3/4ton springs on a half ton. I did it on my 67 way back when. It made it ride cinda rough, but it helped the sag from the old worn out ones.
70rs/ss is offline   Reply With Quote
Old 02-02-2007, 08:34 PM   #4
Prerunner1982
Prerunner1982's Avatar
yes the HD coils or 1 ton coils will do the trick. I ran them on my 82 c10 and could fit 31s ith no rubbing and 32s with slight rub...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-02-2007, 11:21 PM   #5
isenegger
how much taller would they be? anything about ball joints i gotta worry about?
Old 02-05-2007, 07:21 AM   #6
vtblazer
vtblazer's Avatar
I added 3/4 ton springs to the rear of a 71 swb with a 402 and the 1/2 ton shocks couldn't handle the rebound rates of the new springs so the ride was terrible.
Installed some 3/4 ton shocks and it rode sweet after that.
So put the new shocks in while your doing the swap to save the time later.
vtblazer is offline   Reply With Quote
Old 08-17-2007, 12:11 PM   #7
isenegger
what about the ball joints?...any problems with them after the new coils?
Old 08-17-2007, 04:37 PM   #8
kwmech
There should be zero issues with the ball joints. If I remember correctly the length of the coils are the same. The heavier duty coils run a larger diameter wire spring, thus changing the rate
Old 08-18-2007, 03:59 AM   #9
isenegger
changing the rate mean no sag thus lifting the front once the truck is sat back down on the ground?
Old 08-18-2007, 07:25 AM   #10
vtblazer
vtblazer's Avatar
Should definitely sit higher.
Remember about those shocks...
