02-02-2007, 01:33 PM | #1 |
aka TEX-TOY
Dropping?
What is the lowest i can go in the rear without having to c notch my frame?
I was thinking this 2.5 spindles in the fron with 1 or 2 in springs and 4 or 5 in in the rear with springs... thanks
1969 Chevy C10 SWB w/ disk brakes and soon to be lowered with spindles and springs!!!! Getting a paint job like a Army Chinook Helicopter!!!! HOOKERS RULE!! BRAND NEW WIFE BOUGHT IT FOR ME AS A WEDDING GIFT!!! SHE IS THE BOMB!!!!!! |
02-02-2007, 01:55 PM | #2 |
New Member
Re: Dropping?
I was wondering the same thing. I need to do the same thing.....
02-02-2007, 02:30 PM | #3 |
Keep On Keepin' On
Re: Dropping?
I have heard 6" in the back is pushing...I am going 5" myself (w/ a panhard bar)
02-02-2007, 02:36 PM | #4 |
aka TEX-TOY
Re: Dropping?
did you notch your frame for 5?
02-02-2007, 03:12 PM | #5 |
Re: Dropping?
there was a artical in classic trucks where they put the complete cpp kit on a 65 witch is the same as our coil spring set up and they said you could go 6" with no notches. my truck has 6" drop coils from western chassies got them at sport truck direct, only ones i know of that have 6 any how, there is still alot of room between my frame and axle.however if it ever does hit on a launch it will be a wild ride cause the rears will likley unloade so if that happens i will notch it. i would think you will be ok on a daily driver though
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
02-02-2007, 03:36 PM | #6 |
Re: Dropping?
6'' is fine without a notch. There are quite a few of us on here with 6'' drops and no notches. ECE sells 6'' drop coils.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 02-02-2007 at 03:37 PM. |
02-02-2007, 04:37 PM | #7 |
Re: Dropping?
From what I read in past posts is you can go 6" without a notch, but I think you will have very little spring travel in the rear.
02-02-2007, 05:36 PM | #8 |
New Member
Re: Dropping?
If you do go 6 in the rear with no notch, is the ride really bumpy? Or does that depend on the Shocks you use?
02-02-2007, 05:35 PM | #9 |
Re: Dropping?
I know a local guy who used 4" lift blocks from a lift kit in his 67 shorty he said it worked fine I asked about the pinion angle he said he never lost a U-joint Anyone else try this?
02-02-2007, 11:24 PM | #10 |
Re: Dropping?
I use the gray KYB shocks on my truck, the ride is good. The only problem I have is the rear bottoms out on the exhaust once in a while. It's my fault, I routed the exhaust incorrectly for the amount of drop.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
02-03-2007, 12:04 AM | #11 |
WTB this ad
Re: Dropping?
I wanted my truck as low as I could get it without having to notch it. The guys at ECE said a 6" drop wouldn't bottom out unless I was loaded. Well as previously stated a lot of guys run 6" of drop out back without problems but sooner or later you are going to bottom out. Yes, 98% of the time while driving unloaded you will be fine but sooner or later you will bottom out. 5" is probably a lot closer to being a worry free drop. I thought about swapping out my rear springs for 5" springs but I really like the way it looks. I wouldn't call the ride harsh, but yes it is more firm than before it was dropped. My truck has 2.5" drop spindles with 1" drop coils up front. Out back are 6" drop coils along with shock relocators and a super track bar. The trailing arm crossmember was swapped for an ECE extreme drop piece.
This is member 71see10's truck. He has stock height front springs along with 2.5" drop spindles up front. Out back he has 5" drop coils along with the super track bar kit. |
02-03-2007, 12:39 AM | #12 |
Re: Dropping?
I have 4'' drop springs and 2'' lowering blocks
69 shorty w/ 67 front clip |
02-03-2007, 12:41 AM | #13 |
Re: Dropping?
I dont think the photo showed up but it showed that thare is about 4'' of clearance between the axle and the frame
02-03-2007, 01:51 AM | #14 |
Re: Dropping?
i have a 5in drop spring in the back with no problems
69 chevy swb 2.5 in droped spindle with 1 coil cut--5 in dropped spring in rear 5 in dropped spring 307 repaced soon with 350 3sp on tree soon replaced with 350 tubo 06 monte carlo 94 chrysler town & country---198K 84 jag xj6 76 sportster---57 panhead |
