02-03-2007, 11:24 PM | #1 |
Brake question
I did the rear brakes on my '68 C10 today and am wondering what the spring around the outside of the drum is for. I have never seen that before. Thanks
02-03-2007, 11:39 PM | #2 |
Member #1049
Re: Brake question
From what I have heard it was a device to help cool the drum by helping air movement.. But I cannot confirm it.
02-03-2007, 11:53 PM | #3 |
In Memoriam...
Re: Brake question
I dunno either, but I thought it was to help control vibrations which would otherwise result in brake noise. To kinda dampen things a bit.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." Last edited by FarmTruk; 02-03-2007 at 11:54 PM. |
02-04-2007, 12:03 AM | #4 |
Re: Brake question
the spring is supposed to dampen shatter
it's the same thing when they trun a drum (resurface) it on a machine. you will see them wrap a big rubber band (strap) around it. how well it work's? |
02-04-2007, 12:35 AM | #5 |
its all about the +6 inches
Re: Brake question
when i still had the GMC, the drums had these things, when one flew off, that side rang when goin down the road.
Io was pretty p!ssed when i replaced 2 of them, and they had no provisions for the spring. But, luckily, the new ones didn't vibrate, but they did wear VERY poorly. This was the same Q I had my first day i logged onto this site. |
02-04-2007, 12:20 PM | #6 |
Re: Brake question
Thanks guys. I forgot to put one of them on before I put the wheel on so I think I will run without it for a while and see if I notice anything. I'm thinkin' I won't be able to tell the differance.
